12473 Discussions
Cyclone V SOC FPGA: gcc not found with gcc-linaro-arm-linux-gnueabihf installed
I have followed the instruction here to setup toolchain https://rocketboards.org/foswiki/documentation/gitgettingstarted as below:
$ cd ~ $ wget https://launchpad.net/linaro-toolchain-binaries/trunk/2012.11/+download/gcc-linaro-arm-linux-gnueabihf-4.7-2012.11-20121123_linux.tar.bz2 $ tar xjf gcc-linaro-arm-linux-gnueabihf-4.7-2012.11-20121123_linux.tar.bz2 $ export CROSS_COMPILE=~/gcc-linaro-arm-linux-gnueabihf-4.7-2012.11-20121123_linux/bin/arm-linux-gnueabihf-
i have check the env var been set correctly with the CROSS_COMPILE.
However I still not able to compile any file.
It still always prompt out this error for everything I tried to install
/bin/sh: gcc: command not foundmake: *** Error 127 make: *** Error 2
Anyone encounter this before?
Is there any solution for this?
Issue solved....
Can you tell how you were able to resolve this?
