Is it possible to implement Remote Update when:
1. Booting from QSPI attached to FPGA fabric. 2. Booting from QSPI attached to HPS. Would seem the SSBL needs modified for the "user" application - the "factory" application is linked starting at address 0x000000. What tool, with what option, is used to append the second, user, image? I don't see a specific option called out in mkpimage. Has anyone successfully done this? Thanks!Link Copied
The answer is NO - one can't use the HPS and remote update.
--- Quote Start --- The answer is NO - one can't use the HPS and remote update. --- Quote End --- hi everyone please can you tell me how can i boot an RTOS on SD card to install in DE1 Soc without linux, I must have the control console of the kernel on VGA directly so that I can program after a machine control interface; thank's for you
