Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
12473 Discussions
Cyclone V SOC WS-3 linux device driver
Hello All,
I am using Cyclone V from Terasic Soc kit and now trying to make driver for Hps to FPGA bridge.
I have Quartus and SOCEDS 15.0.
I have started with Workshop 3 from rocketboard. https://rocketboards.org/foswiki/view/documentation/ws3developingdriversforalterasoclinux
So, I download image, set ENVIRONMENT variable.
After that I try to execute first example which is lab_module.
So basically I create KBUILD file, make file and after that While, I am trying to executete Make file I got error: makefile:2 *** OUT_DIR is undefined, bad environment. you point OUT_DIR to the linux kernel build ouutput Directory & stop.(PFA)
Basically I am not able to execute make and it seems to be compilation error, and I am not able to build the kernel module.
I already cross check environmental variable, its:
export ARCH=arm; (for ARM achitecture)
export CROSS_COMPILE= <path-to>/toolchain/arm-linux-gnueabihf (cross compiler toolchain)
export OUT_DIR=<path-to>/socfpga-3.10-ltsi (linux kernel source tree)
Could any one help me to solve this?
