I'm trying to use the Hard IP Cyclone V transceiver Native PHY v 15.0 that I create with MegaWizard. I'd like that 2 Gbit/s LVDS signals DATA_P -------------- DATA | LVDS | -----------------|Deserialization|------|8b10b decoder|----- I'd like to have this signal in the end. -------------- DATA_N I'd like to link a LVDS signal on the RX channel. During the instanciation I put DATA_P ( it's a std_logic_vector (0 downto 0)) in the serial data of the transceiver but Quartus II automatically create a DATA_P(n) whereas i created a DATA_N sig declared as a LVDS on the pin planner. (I declared DATA_P as a LVDS) My instanciation of the transceiver is that: Good instanciation? RX_transceiver_2GIGA: transceiver_2_Gbit port map( (others => '0'),--rx_analogreset, (others => '0'),--rx_digitalreset, (others => '0'),--rx_cdr_refclk, DATA_P,--rx_serial_data, --DATA_buffered(0 downto 0) rx_parallel_data_sig,--rx_parallel_data, (others => '0'),--rx_std_coreclkin, rx_std_clkout_sig,--rx_std_clkout, rx_cal_busy_sig,--rx_cal_busy, (others => '0'),--reconfig_to_xcvr, open);--reconfig_from_xcvr); I tried to use a ALIOBUF in differential configuration but it doesn't work. I'd like to know how to use de Clock Data Recovery please? I don't understand de datasheet. Should I use the transceiver reconfiguration controller? Can you help me please?Link Copied
--- Quote Start --- Hello, I'd like to link a LVDS signal on the RX channel. During the instanciation I put DATA_P ( it's a std_logic_vector (0 downto 0)) in the serial data of the transceiver but Quartus II automatically create a DATA_P(n) whereas i created a DATA_N sig declared as a LVDS on the pin planner. (I declared DATA_P as a LVDS) --- Quote End --- As far as I know, if a pin is LVDS, then Quartus expects to see a signal named as the pin planner shows. Personally, I just declare the positive pin of the signal and let quartus fit the negative pin. You can also name a signal SIGNAL and SIGNAL_n and Quartus should automatically pick it up correctly. For you, this would be DATA and DATA_N. Check out http://www.alteraforum.com/forum/showthread.php?t=2707. If you don't need the special buffers, you can always do each pin separately and not declare the LVDS assignment, but this is for the transceivers, which is usually a special case.
Hello, Thanks you for the answer :)
In the pin planner when you choose LVDS the second signal is created!For more complete information about compiler optimizations, see our Optimization Notice.
