12436 Discussions
Cyclone5 ethernet through FPGA unstable (Kernel 4.14.130-ltsi)
MGond1
I have custom board with Cyclon5 where I route ethernet through FPGA splitter to PHY. Splitter it built by rather old Quartus 14.1. I got inspired by this example https://rocketboards.org/foswiki/Projects/CycloneVRGMIIExampleDesign
I use latest Buildroot with Busybox to build the image. Ethernet works for kernel 3.10 without any issues. Now I want to update the Kernel to 4.14.130-ltsi (https://github.com/altera-opensource/linux-socfpga/tree/socfpga-4.14.130-ltsi) and issue with ethernet emerged. If I boot up the board first time with one cable to router, everything works fine like this:
[ 2.781695] libphy: Fixed MDIO Bus: probed [ 2.786145] tun: Universal TUN/TAP device driver, 1.6 [ 2.791586] socfpga-dwmac ff700000.ethernet: PTP uses main clock [ 2.797909] socfpga-dwmac ff700000.ethernet: Ring mode enabled [ 2.803750] socfpga-dwmac ff700000.ethernet: DMA HW capability register supported [ 2.811214] socfpga-dwmac ff700000.ethernet: Enhanced/Alternate descriptors [ 2.818170] socfpga-dwmac ff700000.ethernet: Extended descriptors not supported [ 2.825462] socfpga-dwmac ff700000.ethernet: RX Checksum Offload Engine supported [ 2.832926] socfpga-dwmac ff700000.ethernet: COE Type 2 [ 2.838143] socfpga-dwmac ff700000.ethernet: TX Checksum insertion supported [ 2.855289] libphy: stmmac: probed [ 2.858719] Micrel KSZ9021 Gigabit PHY stmmac-0:01: attached PHY driver [Micrel KSZ9021 Gigabit PHY] (mii_bus:phy_addr=stmmac-0:01, irq=POLL) ... Starting network: udhcpc: started, v1.31.0 udhcpc: sending discover udhcpc: sending discover udhcpc: sending select for 192.168.2.222 udhcpc: lease of 192.168.2.222 obtained, lease time 86400 deleting routers adding dns 192.168.2.1 OK# ethtool eth0 Settings for eth0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supported pause frame use: Symmetric Receive-only Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 100Mb/s Duplex: Full Port: MII PHYAD: 1 Transceiver: internal Auto-negotiation: on Supports Wake-on: d Wake-on: d Current message level: 0x0000003f (63) drv probe link timer ifdown ifup Link detected: yes
But when I run "reboot" to soft-reboot the board, PHY is not found. Like this:
[ 2.779583] libphy: Fixed MDIO Bus: probed [ 2.784038] tun: Universal TUN/TAP device driver, 1.6 [ 2.789496] socfpga-dwmac ff700000.ethernet: PTP uses main clock [ 2.795803] stmmac - user ID: 0x10, Synopsys ID: 0x37 [ 2.800868] socfpga-dwmac ff700000.ethernet: Ring mode enabled [ 2.806696] socfpga-dwmac ff700000.ethernet: DMA HW capability register supported [ 2.814163] socfpga-dwmac ff700000.ethernet: Enhanced/Alternate descriptors [ 2.821120] socfpga-dwmac ff700000.ethernet: Enabled extended descriptors [ 2.827893] socfpga-dwmac ff700000.ethernet: RX Checksum Offload Engine supported [ 2.835358] socfpga-dwmac ff700000.ethernet: COE Type 2 [ 2.840576] socfpga-dwmac ff700000.ethernet: TX Checksum insertion supported [ 2.847619] socfpga-dwmac ff700000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 2.862852] libphy: stmmac: probed [ 2.866270] socfpga-dwmac ff700000.ethernet: No PHY found [ 2.871711] socfpga-dwmac ff700000.ethernet: stmmac_dvr_probe: MDIO bus (id: 0) registration failed [ 2.881261] stmmaceth ff700000.ethernet: PTP uses main clock [ 2.887093] stmmaceth ff700000.ethernet: Ring mode enabled [ 2.892589] stmmaceth ff700000.ethernet: DMA HW capability register supported [ 2.899715] stmmaceth ff700000.ethernet: Enhanced/Alternate descriptors [ 2.906317] stmmaceth ff700000.ethernet: Extended descriptors not supported [ 2.913265] stmmaceth ff700000.ethernet: RX Checksum Offload Engine supported [ 2.920384] stmmaceth ff700000.ethernet: COE Type 2 [ 2.925256] stmmaceth ff700000.ethernet: TX Checksum insertion supported [ 2.939189] libphy: stmmac: probed [ 2.942605] stmmaceth ff700000.ethernet: No PHY found [ 2.947694] stmmaceth ff700000.ethernet: stmmac_dvr_probe: MDIO bus (id: 0) registration failed ... Starting network: Waiting for interface eth0 to appear............... timeout! run-parts: /etc/network/if-pre-up.d/wait_iface: exit status 1 FAIL
Also when Ethernet is up and running and I issue "ip link set eth0 down" the board is rebooted immediately, as if watchdog would reboot the board. The same happens when I unplug the eth cable but I guess, the reason is "ip link set eth0 down" is executed by ifplugd which causing the reboot.
Last nail to the coffin appears when I plug the board to network through the switch (board -> switch -> router). Ethernet wouldn't pick the dhcp and remains unconfigured without ip.
# ethtool eth0 Settings for eth0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supported pause frame use: Symmetric Receive-only Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 100baseT/Full Advertised pause frame use: No Advertised auto-negotiation: No Advertised FEC modes: Not reported Speed: 100Mb/s Duplex: Full Port: MII PHYAD: 1 Transceiver: internal Auto-negotiation: off Supports Wake-on: d Wake-on: d Current message level: 0x0000003f (63) drv probe link timer ifdown ifup Link detected: yes
I tried to lower PHY speed to 100Mb, doesn't help.
I attached the .dts file, global config and linux .config below. If you have any idea how to proceed with debugging or what is wrong, please, let me know.
Thank you.
bekl
I have a similar Problem. Custom board with Cyclon5. Quartuns 14.1 used for hardware design. Preloader and u-boot genrated with 14.1 (u-boot 2013.1). Using Yocto Project like described on rocketboards i can generate a rootfs. My Kernel was alswas 3.10-ltsi-rt which wors fine with yocto 2.0 and yocto 2.7 e.g. When i compile a new kernel now (>4.x) and replace my existing kernel i have problem with eth0.
while boot searial terminal shows something like:
stmmaceth ff700000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
ifconfig just shows loopback interface.
ip link show shows also eth0:
 eth0: <BROADCAST,MULTICAST8000> mtu 1500 qdisc noop qlen 1000
  link/ether 2e:76:4d:e6:80:14 brd ff:ff:ff:ff:ff:ff
When running ip link set up eth0 i get following error:
ip: SIOCSIFFLAGS: No such device
Using a newer u-boot than 2013 is also problematic cause then my board does not even boot. I thought that i maybe need to regenerate the preloader and dtb file and so on. But i got some issues there as well therefore i try to run with u-boot 2013 further.
So if you have a solution for your problem maybe it could also resolve mine. I have tried 5-10 different kernels >4.x. Kernel up to <4.0 work fine.
Thanks in advance.
Best regards
