I am getting the following critical warning
Critical Warning: ALTMEMPHY PLL, Nios_Only:inst|Nios_Only_altmemddr:altmemddr|Nios_Only_altmemddr_controller_phy:Nios_Only_altmemddr_controller_phy_inst|Nios_Only_altmemddr_phy:Nios_Only_altmemddr_phy_inst|Nios_Only_altmemddr_phy_alt_mem_phy:Nios_Only_altmemddr_phy_alt_mem_phy_inst|Nios_Only_altmemddr_phy_alt_mem_phy_clk_reset:clk|Nios_Only_altmemddr_phy_alt_mem_phy_pll:pll|altpll:altpll_component|altpll_g5l3:auto_generated|clk[1], when fed by another PLL, must have bandwidth mode set to High instead of Medium I believe this is because my NIOS system is being fed from another PLL. What I can't work out is where do I change the bandwidth mode in the Altmemphy controller. Can someone point me in the right direction? ThanksLink Copied
