Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
DDR3 "verify fail" when applying little modifications in Qsys
Hi ,
I have designed a NIOS II-e based system running on DDR3 memory and the system works fine but when I do small modifications in QSys (eg. add an interval timer) in some cases I face "verify failed" when programming NIOS2.
My platform is Stratix IV Development Kit. NIOS II processor is connected to DDR3 controller reset and clock(afi_half_clock: 75Mhz).
Thanks in advance
I'm having the same problem with DE4 board when using DDR2 memory for instrucion of NIOS. Could you solve the problem?
