12604 Discussions
DE0-Nano and I2C Opencores Issues
Finally had a chance sit down and play around with DE0-Nano. I am using Quartus/Qsys 11.1 and Nios II 11.1 Software build tools.
I thought as a relatively quick project I would experiment using the opencores I2C master downloaded from alterawiki.com/wiki/I2C_(OpenCores) to interface with the ADXL345 accelerometer and 24LC02B eeprom ICs on the DE0-Nano board.
The first problem I hit was with the version of Qsys required by the I2C master (12.0 vs 11.1). I simply used the 'New component' wizard in Qsys to generate the new _hw.tcl file with the following wishbone to avalon bus signal assignments:
wb_clk_i --- clk
wb_rst_i --- reset
wb_adr_i --- address
wb_we_i --- write
wb_ack_o --- waitrequrest_n
wb_dat_i --- writedata
wb_dat_o --- readdata
wb_stb_i --- chipselect
wb_inta_o --- irq
scl_pad_io --- export
sda_pad_io --- export
I then made the following pin assignments
scl_pad_io == PIN F2 (output)
sda_pad_io == PIN F1 (bi-dir)
PIN G5 (G_SENSOR_CS_N) I tied to VCC to ensure the accelerometer is in I2C mode rather than SPI mode.
I had a few more niggles after this, specifically getting the driver to be recognised by Nios II IDE. Turns out I had to rename all instances of opencores_I2C to I2C_opencores in the _sw.tcl file.
Now I have the following code which is running on the DE0-Nano, which should write 0x55 to the first byte of the eeprom and read back the same byte as a second I2C transaction. The eeprom 7-bit address should be 0x50 (assuming I have found the correct datasheet). The software functions are defined with I2C_opencores available from the link above.
//Intialise I2C master controller at 100kHz, 50MHz Cpu clock.
I2C_init(I2C0_BASE,ALT_CPU_CPU_FREQ,100000);
// Write 0x55 to location 0x0 for I2C device at 0x50 (22LC02B)
I2C_start(I2C0_BASE,0x50,0);
I2C_write(I2C0_BASE,0x0,0);
I2C_write(I2C0_BASE,0x55,1);
// Write address that is to be read from
// Read from the device
I2C_start(I2C0_BASE,0x50,1);
data = I2C_read(I2C0_BASE,1);
printf("Data: 0x%x \n",data);
However I get the following console output if I defined I2C_DEBUG...
Initializing I2C at 0x40040b0,
with clock speed 0x2faf080
and SCL speed 0xc350
and prescale 0xc7
Start I2C at 0x40040b0,
with address 0x50
and r/w 0x0
NOACK
Write I2C at 0x40040b0,
with data 0x0,
with last 0x0
ACK
with data 0x55,
with last 0x1
ACK
with address 0x50
and r/w 0x0
NOACK
with data 0x0,
with last 0x0
ACK
with address 0x50
and r/w 0x1
NOACK
Read I2C at 0x40040b0,
with last 0x1
Data: 0x50dc5a0f
What I don't understand is why I am getting an NOACK response from the start transaction, but do get an ACK response from the following write transaction. Without a scope/logic analyser I am a bit stuck as to what could be going wrong.
Hope there is someone out there who has had a similar experience to me and will be able to help me out.
Hi there,
I'm working on the adxl345 on DE0-nano board for my university project,
and I have the same problems with My nios program in eclipse IDE .
I'm using Quartus 11.1 and I will appreciating if you send me the programs.
when I run the program It does not even start the transmitting and I suspect my sw.tcl or one other file is corrupted by the changes that I did to those files,
Anybody knows how can I run this core into my design??
I'd appreciating if somebody help me.
farshid_mfc[at]yahoo.com
H there,
I have taken a module from http://www.eewiki.net/display/logic/i2c+master+%28vhdl%29 when integrating to the Avalon bus i have had some issues. This is not wishbone compliant and my plan was to write my own wrapper but with time running out i was an unit testing needed i was wondering if;
Altera supply a bus similar to that of the clock crossing bridge?
Hi there,
I have a DE0 Nano as well, and I am using the same versions of Quartus/Qsys and Nios II, but for some reason I dont have any signal at the scl_pad_io or sda_pad_io pins (they are asssigned to pins on the GPIO header). I know it's been a long while since this thread was last active, but if you could help me I would appreciate it a lot :)
Cheers,
Salman
