DE1 AUDIO CODEC help needed
I am using DE1-SOC audio codec. I have sound by linking ADCDAT to DACDAT. I do this with a switch. So I can disable sound or listen to it by using this switch.
The next step is to make a 24 bits left and right data from ADCDAT and then manipulate it and get it back to DACDAT.
So I made 2 processes:
The following converting ADCDAT to 24 bits data left and right
PROCESS(BCLK,NRST)
BEGIN
if NRST = '0' then
AUD_DACLRCK_OLD <= '1';
GO <= '0' ;
index <= 0 ;
ch <= 0;
temp <= conv_std_logic_vector(0, 24) ;
elsif rising_edge(BCLK) then
if AUD_DACLRCK_OLD = '1' AND AUD_DACLRCK = '0' then
ch <= 1;
AUD_DACLRCK_OLD <= '0' ;
index <= 24;
end if;
if AUD_DACLRCK_OLD = '0' AND AUD_DACLRCK = '1' then
AUD_DACLRCK_OLD <= '1' ;
ch <= 2;
index <= 24 ;
end if;
if ch = 1 then
if index >= 0 then
temp(index) <= AUD_ADCDAT ;
end if;
index <= index - 1 ;
if index = -1 then RES_LEFT <= temp(23 downto 0) ; ch <= 0;end if;
end if;
if ch = 2 then
if index >= 0 then
temp(index) <= AUD_ADCDAT ; end if;
if index = -1 then RES_RIGHT <= temp(23 downto 0) ; ch <= 0; end if;
end if;
end if; --rising_edge
END PROCESS;
For getting it back to 1 bit:
PROCESS(BCLK,NRST)
variable i,j : integer;
BEGIN
if NRST = '0' then
i := 0; j := 0;
LR <= '0';
GO <= '0';
--if rising_edge(START) and GO = '0' then
AUD_DACLRCK_OLD <= AUD_DACLRCK;
ch <= 0;ch2 <= 1;
data_left <= datain_left;
data_right <= datain_right;
j := 24 ;
end if;
ch <= 1; ch2 <= 0;
i := 24;
end if;
if (ch = 1) then
if i >=0 and i <= 23 then AUD_DACDAT <= data_left(i) ;end if;
i:= i-1;
elsif (ch2 = 1) then
if j >=0 and j <= 23 then AUD_DACDAT <= data_right(j) ;end if;
j:= j-1;
end if; --GO
if i <0 then ch <= 0; end if;
if j <0 then ch2 <= 0; end if;
end if;
END PROCESS;
So if I connect ADCDAT to DACDAT I get perfect sound. But if I do it as above I get too much noise.
Any idea?
I appriciate your help...
