DE1-SOC SD card file system
I wanted to run the arm inside the DE1-SOC board. I created the bsp using the bsp-editor and compiled it. Now I have the preloader-mkpimage.bin file. I wanted to copy it to the SD Card. I noticed that it is not just copy and paste, but the sd card should have some sort of a file system. I could not figure that out. How can I make the SD card valid for the ARM to load the preloader then the uboot?
I use Win 7.
Yes you are right. For the preloader it is not just copy and paste. This page has the info for you:
https://rocketboards.org/foswiki/view/documentation/gsrd131sdcard
In short, you need to mount your SDCard in linux system and then run:
$ sudo dd if=preloader-mkpimage.bin of=/dev/sdx3 bs=64k seek=0
where "sdx" is the device name of your SDCard. In my case it is "sdb" because I only have one other hard drive, which is mounted as "sda"
Thank you for your reply.
I could find another solution on windows by using Win32DiskImager tool and prebult linux image from SOCEDS tool folder. The Win32DiskImager formats the card by the required partitions and then the FAT drive contains the preloader and uboot/baremetal_app
