Board : DE2-115
Software : QuartusII 10.0 + NiosII IDE 10.0 i have been doing : Working the simple socket server in the niosII IDE basic project. (Use the DE2_115_web_server sopc) and modify the error completely problem 1. i use the instruction "IOWR" and "IORD" including "io.h" storing/loading SDRAM address, but how to put the instruction into simple_socket_server.c . I can't realize the process about it. let's a simple goal : (1)declare a data[10] = {0,1,2,3,4,5,6,7,8,9} and store data into SDRAM. (2)loading the data from SDRAM, then, transmit the data to connector by ethernet. >> i think the SSS project work with ucosii. whether i need to realize the ucosii structure or not ... ? the final goal just receive data from the other board and transmit data to connector(pc). how do i start ?Link Copied
Why don't you just use an array? Either a static table or one dynamically allocated with malloc().
