12603 Discussions
DE2-115 wiring Triple-Speed-Ethernet
Hello, I am trying to use the TSE-Mac but I am not sure if my wiring is correct.
I tried to port it from the Altera example (ftp://ftp.altera.com/up/pub/altera_material/14.0/tutorials/de2-115/).
The problem is, i am using bdf-File as Top-Level-Entity and all the examples don't.
Can someone please have a look at it?
My Project: http://itexplorer.de/downloads/de2_115_uclinux.zip
With best regards,
Jan
EDIT:
I found two mistakes by myself: i mixed up rx and tx clock and i missed an "not" on mdio_oen.
Now i can set up eth0 but can´t ping or get pinged.. :/
I would suggest you to refer to the TSE Megacore resource center, from there you may found some useful example that you may refer to:
https://www.altera.com/support/support-resources/intellectual-property/interface-protocols/triple-speed-ethernet/ips-inp-tse.html
--- Quote Start ---
--- Quote End ---
Thank you for your reply. In the meantime I figured it out by myself. I had to make some entry's in my .sdc-File.
Can you share which entries you had to enter?
--- Quote Start ---
--- Quote End ---
I ziped the top.vhd and the SDC-File for you ;)
Thanks for sharing. I noticed in your design that you have an MMC and a CFI. Is this where you had the Linux to boot from?
I'm using the MMC for the Root-File-System and the CFI for storing the Kernelimage.
