DMA Example HAL
Have anyone a good sample how works with DMA in HAL mode? I need something
like to project Streaming with irq and streaming transfer. Thank you so much for any help http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
I&#39;ve made it next:
unsigned int *p = (unsigned int*)(SDRAM_BASE + 0xF4240);
void *pdma = (void*) SD_DMA_BASE;
void isr_dma(void* context, alt_u32 id)
if ((IORD_ALTERA_AVALON_DMA_STATUS(SD_DMA_BASE))&&0x01) {
IOWR_ALTERA_AVALON_DMA_STATUS(SD_DMA_BASE, 0);
IOWR_ALTERA_AVALON_DMA_RADDRESS(SD_DMA_BASE, (int)p);
IOWR_ALTERA_AVALON_DMA_WADDRESS(SD_DMA_BASE, SD_BASE);
IOWR_ALTERA_AVALON_DMA_LENGTH(SD_DMA_BASE, 40);
IOWR_ALTERA_AVALON_DMA_CONTROL(SD_DMA_BASE, 0x02DC);
int main(void)
//Write to memory something (in this case 10 words)
for (i=0, pattern=0xFFAAFFAA; i<10; i++)
IOWR_32DIRECT(p+i, 0, pattern);
alt_irq_register(SD_DMA_IRQ, pdma, isr_dma);
//Send to some device 10 words
Just to clarify, that&#39;s _not_ an example of the use of the DMA HAL - it&#39;s a demonstration of how to do a DMA transaction with direct register reads and writes.
By the way, instead of
if ((IORD_ALTERA_AVALON_DMA_STATUS(SD_DMA_BASE)) && 0x01)
you want:
if ((IORD_ALTERA_AVALON_DMA_STATUS(SD_DMA_BASE)) & 0x01)
even better:
ALTERA_AVALON_DMA_STATUS_DONE_MSK)
