DMA fails to transmit
On my Cyclone IV FPGA Development board, I have built a Qsys system with Nios II processor and two standard linear DMAs, and I am DMA'ing data from one on-chip memory buffer to another through a data processing block. After the first pass of the DMA runs, I update the contents in the source buffer and repeat the process. I need to repeat this over several MB of data, so will need to do this a few thousand times. Unfortunately, the process fails after the 3rd iteration of the DMA with this message: "Failed to post CH_DMA transmit request, reason = " (i.e. no error code printed out).
Not sure why the DMA would fail on the 4th pass. Is this a situation anyone has encountered before?
Here is the crux of the code I'm using:
// ENABLE CH_DMA(s)
// Use CH_DMA to move data from CH_FIFO into CH_BUFFER:
if ((CH_dma_txchan = alt_dma_txchan_open("/dev/ch_dma")) == NULL)
alt_printf ("Failed to open CH_DMA transmit channel\n");
exit (1);
// Create the receive channel
if ((CH_dma_rxchan = alt_dma_rxchan_open("/dev/ch_dma")) == NULL)
alt_printf ("Failed to open CH_DMA receive channel\n");
exit (1);
// Lock the CH_DMA transmit (ie. read) channel to CH0_FIFO
alt_dma_rxchan_ioctl(CH_dma_rxchan, ALT_DMA_RX_ONLY_ON, (void *)CH_DMA_READ_MASTER_CH_FIFO_BASE);
// ENABLE ABC_DMA:
// Use ABC_DMA to move data from ABC_DATA into ABC_FIFO:
if ((ABC_dma_txchan = alt_dma_txchan_open("/dev/ABC_DMA")) == NULL)
alt_printf ("Failed to open ABC_DMA transmit channel\n");
exit (1);
if ((ABC_dma_rxchan = alt_dma_rxchan_open("/dev/ABC_DMA")) == NULL)
alt_printf ("Failed to open ABC_DMA receive channel\n");
exit (1);
// Lock ABC_DMA rx (destination) channel to ABC_FIFO
alt_dma_txchan_ioctl(ABC_dma_txchan, ALT_DMA_TX_ONLY_ON, (void*) ABC_DMA_WRITE_MASTER_ABC_FIFO_BASE);
// Start superloop
while (1) {
// Flush Nios II Data Cache
alt_dcache_flush_all();
// POST CH_DMA:
// Post CH_DMA transmit request:
if ((rc = alt_dma_txchan_send (CH_dma_txchan,(void *)CH_DMA_READ_MASTER_CH_FIFO_BASE,bytes,NULL,NULL)) < 0)
alt_printf ("Failed to post CH_DMA transmit request, reason = %i\n", rc);
exit (1);
// Post CH0_DMA receive request:
if ((rc = alt_dma_rxchan_prepare (CH_dma_rxchan,(void *)CH_DMA_WRITE_MASTER_CH_BUFFER_BASE,bytes,CH_dma_done, NULL)) < 0)
alt_printf ("Failed to post read request, reason = %i\n", rc);
exit (1);
// POST ABC_DMA:
// Post ABC_DMA transmit request:
if ((rc = alt_dma_txchan_send (ABC_dma_txchan,(void *)ABC_DMA_READ_MASTER_ABC_DATA_BASE,bytes,ABC_dma_done,NULL)) < 0)
alt_printf ("Failed to post ABC_DMA transmit request, reason = %i\n", rc);
exit (1);
// Vary LEDs
IOWR(LED_PIO_BASE,0,0xAA);
// Wait until buffer(s) is filled up then proceed
while (!(ABC_dma_complete && CH_dma_complete)) {
IOWR(LED_PIO_BASE,0,0xFF);
// Turn appropriate LED on indicating which channel(s) transfer is complete
IOWR(LED_PIO_BASE,0,0xFE);
// Check data in buffer(s)
// Format in Memory: {XYZ} LITTLE ENDIAN
// A <-> X B <-> Y C <-> Z
# ifdef echo
printf ("\nReading final contents of CH_BUFFER:\n");
read_data = (int*) CH_BUFFER_BASE;
// Check XYZ data values
for (j=0; j <= (words-1); j++)
printf(" 0x%-.8x", read_data[j]);
X = (X_val << 16) & 0xFF0000; // MSB
Y = (X_val+1 << 8) & 0xFF00;
Z = (X_val+2 ) & 0xFF; // LSB
Exp_Value = X | Y | Z;
printf(" Expected value = 0x%.8x",Exp_Value);
if (read_data[j] == Exp_Value)
printf(" - Passed\n");
else
printf(" - Failed\n");
X_val = X_val + 3;
// Init ABC_DATA with NON-default values
write_data = (int*) ABC_DATA_BASE;
A = (R_val << 16) & 0xFF0000; // MSB
B = (R_val+1 << 8) & 0xFF00;
C = (R_val+2 ) & 0xFF; // LSB
ABC_Value = A | B | C;
*write_data = ABC_Value;
write_data++;
A_val = A_val + 3;
# endif
// Pause then repeat with updated values
# ifdef echo
printf("\nPausing...\n\n");
# endif
usleep(1000000);
printf("\nEnd of iteration\n");
// Reset flags
ABC_dma_complete = 0;
CH_dma_complete = 0;
printf("\nPress Enter to proceed with program.");
GetInputString(line,sizeof(line),stdin);
} // end of superloop
Thank you for any help.
