12603 Discussions
DMA transaction between SDRAM and a UART
I would like to begin a DMA transaction between SDRAM and a UART on my Nios Development kit.
This is the code:
while(1)
IOWR_8DIRECT(DMA_BASE,1,SDRAM_BASE); // read address
IOWR_8DIRECT(DMA_BASE,2,UART_0_BASE); // write address
IOWR_8DIRECT(DMA_BASE,3,768); //length
IOWR_8DIRECT(DMA_BASE,6,0x281); // config
IOWR_8DIRECT(DMA_BASE,6,0x289); //GO!
i=IORD_8DIRECT(DMA_BASE,0); //read status
usleep(1000000);
i equals 0 if I put a breakpoint on the usleep line (after the delay, it always equals 0) ; at least the BUSY or DONE bit should be high.
I obtain nothing on the output pin (seen with an oscilloscope; I obtain data if I "fputc" them).
Any ideas?
Marco Lazzaroni
Marco,
Try using IOWR_32DIRECT instead of IOWR_8DIRECT - the DMA registers are aligned to 4-byte boundaries.
