12603 Discussions
DS-5 does not contain Altera Baremetal GCC and linker
In my "Eclipse DS-5-> C Project" there is not Altera Baremetal GCC and linker.
is there any way to install it?
Maybe you should choose "makefile project" in the project type dialog.
I've got same problems. When i'm creating new project there is only one toolchain exist - ARM Compiler. I'm using quartus 13.1 & SoCEDS 13.1. Is there any solution exist?
hey, did you find the solution to this problem? I am also facing the same problem and not able to figure out the solution.
Eclipse for DS-5 doesn't have a template for GCC. Only the ARM compiler (which isn't available in the free version). You need to make your own makefile to build your project.
Thank you Galfonz
