Hi
I am in the middle of a hardware bringup which should boot from qspi. Quad SPI Flash silicon ID is 0x1017BA20. This is unfortunatly a not supported flash script by quartus_hps. So i thought i could use the DS-5 debugger to flash the QSPI or better yet initialize the DDR-RAM settings via DS-5 debugger script? Could you please provide a solution for this problem. Best Regards TimLink Copied
