Hallo, every one:
I have a big Problem to ask here and i need your help: We use the Altera Cyclone V SOC(Cortex A9) Chip in our project. Wenn we work under DS-5. with Debug directly in DS-5 there is no Problem, but i want with DS-5 Command Prompt using "debugger" command to debug our Chip, so i have found some info: -> debugger --target --script ... so what should i do with the target Option? i have tryed with our gdbserver(127.0.0.1:3010), but it do not worked, then i must use a RVC file or what(how can i get the RVC file)? Could someone help me? Thanks a lot, Guys! MfG! wenguo huLink Copied
Hi
It is not to run debugger, but may help to start with DS-5 command line :) http://community.arm.com/message/16275#16275
