12604 Discussions
DTB i've created from .sopcinfo --> doesn't work
Hi All,
I'm working on a custom board - assembly with arria5 device ( booting linux from QSPI ).
Linux is running if i using socfpga_arria5_socdk.dtb ( from : arch/arm/boot/dts/ ) - original of EVB.
If I using my DTB ( from sopcinfo ) - the linux doesn't run , it stuck on "starting kernel" .
My convert process:
- Converting the .sopcinfo ( from my QSYS poject ) to DTS using sopc2dts.exe tool.
- Changing console from ttyAL0 to ttyS0 in the DTS.
- Copy the DTS to my kernel's DTS folder (change the name to socfpga_arria5_socdk.dts )
- Run "make ARCH = arm dtbs"
please advise how should i convert/use .sopcinfo file.
Thanks in advanced,
Moran.
