Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
Data transfer
Honored Contributor I
After having captured data from an ADC and stored it to the SDRAM on the DE0-Nano, what's the best way to transfer this data to the PC?
I am currently just sending it over the JTAG UART using printf commands, but this is very slow and because I have to use the nios2-terminal I can't do anything more low level. Presumably I would see a speed increase if I just used a UART out to the pins and then a serial-USB adapter. Does anyone have any other suggestions?
Bert
WIthout really doing much work, you could add the JTAG Avalon-MM Master and switch over to writing TCL scripts within system-console to directly grab the buffer contents out of SDRAM.
http://www.alterawiki.com/wiki/system_console
--- Quote Start ---
--- Quote End ---
Using the USB-Blaster as an Avalon-MM master is described in this tutorial;
http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial
FTDI have a series of USB-to-FIFO and USB-to-UART cables that also work well. Using these cables allows you to avoid using any Altera tools for communications.
http://www.ovro.caltech.edu/~dwh/correlator/pdf/ftdi.pdf
http://www.digikey.com/product-detail/en/c232hm-ddhsl-0/768-1106-nd/2714139
Cheers,
Dave
