I want to build default De0-Nano-SoC,
for the same i have followed https://hackmd.io/iwqwlmdsweygtauzgnnmgbmanpekaoyeabjagmurmwjsccg=?both#14-install-arm-linux-gnueabi... when i tried for 'make all' to build default ghrd project in product cd, i got error as follows. make: *** No rule to make target 'output_files/soc_system.sof', needed by 'output_files/soc_system.rbf'. Stop. what is this error , how can i remove this error?Link Copied
Have you unzipped the contents of the CD and installed it? If so are you running the "make all" command from the respective directory "/soc/ghrd/" for the DE0 nano board?- Mark as New
I did not get anything (in downloaded CD) like i can install on my Ubuntu host system, i have installed everything mentioned in link
https://hackmd.io/iwqwlmdsweygtauzgnnmgbmanpekaoyeabjagmurmwjsccg=?both#14-install-arm-linux-gnueabi... (toolchain, Quartus ,Soc EDS ) did i forget to install anything?
