Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Debugger and disassembly.
Hello.
How to make steps and set breakpoints in disassembly?
for example i have following code.
   g_unOnchipRamBase = ONCHIP_RAM_BASE; 0x0100046c <InitIHEX+12>: movhi r2,528 0x01000470 <InitIHEX+16>: addi  r2,r2,0 0x01000474 <InitIHEX+20>: stw   r2,-32660(gp)
if i&#39;ll press F5 i will go through these all asm lines.
but, for example, i want to set breakpoint on line "addi r2,r2,0" or more important, i want execute code by single instruction in disassembly.
how?
Highlighted
1. You can set a breakpoing but double click the left edge of the line.
2. <div class='quotetop'>QUOTE </div>
--- Quote Start ---
How to execute code by single instruction in disassembly.[/b]
--- Quote End ---
In Debug Perspective, there is a tool in tool bar, named Use Step Filter/Step Debug, enable it then you can step in disassemble code.
David
Highlighted
Thank you
