hi,
I am having difficulties generating a device tree from the GHRD. I've followed the Rocketboards example (http://rocketboards.org/foswiki/documentation/gsrddevicetreegenerator) and I'm getting the following error. Any ideas why I'm seeing this? Precision-M4600:~/cv_soc_devkit_ghrd$ sopc2dts --input soc_system.sopcinfo\--output socfpga.dts\--board soc_system_board_info.xml\--board hps_clock_info.xml Don't know how to parse hps_clock_info.xml at sopc2dts.LogEntry.<init>(LogEntry.java:37) at sopc2dts.Logger.logln(Logger.java:78) at sopc2dts.Logger.logln(Logger.java:74) at sopc2dts.parsers.BasicSystemLoader.loadSystem(BasicSystemLoader.java:55) at Sopc2DTS.go(Sopc2DTS.java:182) at Sopc2DTS.main(Sopc2DTS.java:80) Loading of system failed. at sopc2dts.LogEntry.<init>(LogEntry.java:37) at sopc2dts.Logger.logln(Logger.java:78) at sopc2dts.Logger.logln(Logger.java:74) at sopc2dts.parsers.BasicSystemLoader.loadSystem(BasicSystemLoader.java:59) at Sopc2DTS.go(Sopc2DTS.java:182) at Sopc2DTS.main(Sopc2DTS.java:80) Thank you in advanceLink Copied
Not sure why you posted the message twice, but here's my reply to your other post for future reference : --- Quote Start --- Hello, I did it in a different way using the git repo :git clone git://git.rocketboards.org/sopc-tools.git
cd sopc-tools/sopc2dts
make
java -jar sopc2dts.jar -b <path/to/hps_clock_info.xml> -b <path/to/**_board_info.xml> -i <path/to/**.sopcinfo> -o socfpga.dts
Hope this helps ! --- Quote End ---
