We have DE0 (Developement and Education) board and we have a supporting software along with the Board.
While we are implementing the its my first FPGA Project as per the guide lines given in the pdf given by ALTERA, pin assignment is not matching the pin details as mentioned in the document and we are unable to compile the project. Kindly provide the guidelines for resolving the problem. Thanks & Regards M.Murali KrishnaLink Copied
Can you provide more details?
PS: In the CD that accompanies the board, there should be some example projects, which should have correct pin assignments.- Mark as New
I am learning FPGA through online training from ALTERS
As a part of on line training i tried to implement the "How to Begin a simple FPGA Design". I followed the procedure given in the "tt_my_first_fpga" PDF for implementing the counter example. We have DE0 board along with the software. I followed as per the PDF, every thing is ok but at the end where we have to assign Pins, the pin number as mentioned in the example is not matching with S/W. In PDF, pin numbers are mentioned as ad0 , where as in the s/w in the S/W i am not viewing AD0 but i am i able to A0. pl. suggest the solution. Thanks & Regards M.Murali Krishna- Mark as New
I would check if you have selected your device correctly in the wizard.
If you have, refer to the FPGA's datasheet for a list of the pins.- Mark as New
Selected the device number correctly. The deivice in DE0 board is
Cyclone III EP3C16F484. "tt_my_first_fpga" in the PDF there is no option for DE0 board. but there is option for development board. As per PDF we suppose to select AD0 pin but only A0 pin is possible to select. if i select A0 pin, compiler is giving errors.- Mark as New
You can't select the pins of another dev kit to use in your design. You need to select the pins according to your DE0 since the pins would be connected differently.
Your DE0 datasheet should give you a list of all the pins. Change the pins according to the datasheet and don't follow the other pdf.
