Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Downloading ELF Process failed
PC:
Altera 10.0sp1, Nios IDE10.0sp1; Win7 32bit ultimate Chinese edition
when i use on chip memory,every goes well.but when i use sdram controller,try many times,the same error.
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x00000000: verified
Initializing CPU cache (if present)
OK
Downloading 01000000 ( 0%)
Downloading 01003D58 (63%)
Downloaded 16KB in 0.2s (80.0KB/s)
Verifying 01000000 ( 0%)
Verify failed between address 0x1000000 and 0x1002723
Leaving target processor paused
the log:
Downloading ELF Process failed,An exception stack trace is not available.
Failed Executing: [nios2-download, '--cable=USB-Blaster on localhost [USB-0]', --device=1, --instance=0,
CPU master group not set.
CPU architecture type not set.
what should i do?thank you !
Hi mikedsouze
Thanks for your support. I have solved the problem.
Rupok
Hello Rupok,
Can you share your solution ?
I've the similar problem and can't resolve it since 3 days.
I've tried 2 different projects - one with On-Chip memory, other with SDRAM.
The result is the same in both cases - downloading begins ... then fails suddenly.
Here is the message in console:
Using cable "DE-SoC [USB-1]", device 2, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Thanks in advance.
Pavel.
check the resets and clock signals to the core CPU. I'd say there is a good chance either that it's not receiving any clock or that it's stuck in reset. For example with the wrong polarity defined on the reset input.
JMuri1
I found out that I had not moved one of the keys on my MAX 10 board up to the correct position. By moving key 9 to the up position Nios II was able to upload the ELF file without a problem.
/James
