12589 Discussions
Downloading ELF Process failed!
I am running NiosII IDE on my windows 7 professional laptop. When I first create a sopc project and complie and download *.sof into target board, then I also create a demo NiosII project "Hello world!" and debug it normally. Howerver, after I close NiosII IDE and restart it, I cann't debug it anymore eventhrough I don't change anything in both Quartus and sopc. It gives me a prompt that "Lanching hello_test Nios II hardware configuration has encourntered a problem. Downloading ELF Process failed". No matter I restart my laptop or power off my target board, it doesn't work! If I rebuild a new same sopc project and rebuild a new same NiosII project, it can work.But there is the same problem if I close it and restart it again. Please help me!:confused::confused::confused:
Which NIOS II IDE version a u using?
I am using NiosII 10.0 SP1.
Sounds like the problem I have every time I restart Quartus (which, as often as it crashes, is very often).
Try your first download after restarting from "Run Configurations..." rather than directly running something from the launch history. Once it gets back in sync, then running from the launch history works until you restart Quartus.
--- Quote Start ---
--- Quote End ---
Dear Dong: There is no-way enen I restart my computer!
First off, I'd try getting the IDE/SBT for Eclipse out of the way.... From a "Nios II Command Shell" (or a properly configured shell on Linux) change directories to where your ELF file is stored and type the following command:
nios2-download -g <your ELF.elf> && nios2-terminal
and report what you see back here. If this command doesn't appear to work, please also try typing:
jtagconfig -n
and report the results here, as well.
This will help to determine whether the issue you're seeing is GUI/Eclipse related, JTAG chain related, hardware/FPGA design related or...something else.
Cheers,
-- slacker
Amruth
Hii
I am also facing the same error for simple soc design on stratix 10 MX FPGA. I checked the connections, configurations and tried running through nios II command shell. But getting the error
Using cable "Intel Stratix 10 MX FPGA Development Kit [2-1.2]", device 1, instance 0x00
Pausing target processor: not responding
Resetting and trying again: FAILED
Leaving target processor paused
My quarters prime edition is 18.1.2 pro. Can you please help me out.
--- Quote Start ---
--- Quote End ---
I finially fix it by updating NiosII 10.0 sp1 to 10.1. Downloading the program after "Run Configurations..." to check whether the mcu is in sync. Maybe Version 10.0 sp1 is a bug one.
Try to remove the terminal before quiting NIOS2-IDE, click on the red button in the console to finish the connection before you quit NIOS-IDE.
By the way, use the console. Nios-ide is too buggy
I have same error, followed your commands, the result is
USB-Blaster [USB-0]
020F400DD EP3C40
node 19104601
node 1910 4600
node 0C006E01
Node 0C006E00
Slacker can you say sth for me.
Thuy,
You have two processors and two jtag_uarts then? You need to be sure that you've hooked up everything properly in SOPC Builder and then you need to tell the tools which processor you're downloading to and from which jtag_uart console will function.
From the GUI, I'm not entirely sure how this would work, but from the command line their are arguments for both nios2-download and nios2-terminal that can deal with this...
Good Luck!
Slacker
Thank you so much for your reply, Slacker. I appreciate that.
Yes I did add cpu_0 and cpu_1 intentionally because I want to play 2 cores at the same time later. I did select with Eclipse from the time creating new project in C and when run as configuration, but the ELF loading still failed. Even when I deleted cpu_1 and juart_1, run as above and got same error.
Notice that with the same sopc file I could see "hello world" with another version of board (unwanted version). So I believe the problem is in the hardware of the FPGA. but not sure what kind of things may happen? I checked very carefully the scheme. could not find yet.
As I read, people talked much about clk and reset_n, but even with reset_n of onchip mem connected to Vcc it still worked with unwanted version board.
another clue, the main difference vs. the worked board is :
the init_done, config_done, nstatus n_config are pulled up to 3.3V with 10K (supposed to be right) all VCCD_PLL to 1.2V instead of 2.5 V (should be right too) many IO pins are set free instead of mislabled and connected to GND or VCCINT.
It's so funny that the version with many mistakes worked and the corrected one does not work.
Please suggest me something to investigate more.
Refresh Connections in Target Connection,if it still like before,close it and reconfiguration,it maybe OK.
I am currently working with the last version of the tools (Quartus II 10.1 SP1 and Nios II SBT 10.1 SP1) and I have to same problem as described initially in the thread:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x01201010: verified
Initializing CPU cache (if present)
OK
Downloading 01100020 ( 0%)
Downloading 01110000 (44%)
Downloading 01120000 (89%)
Downloaded 144KB in 2.4s (60.0KB/s)
Verifying 01100020 ( 0%)
Verify failed between address 0x1100020 and 0x110FFFF
This always happens when the code size is above 64kB (0x00010000). Sometimes at the beginning, sometimes afterwards. But always during the veryfing process.
The design I use is rather small (CPU + JTAG-UART + SYSID + AVALON-TRISTATE-BRIDGE + SRAM + CFI + PIO).
I try the download command from the shell but th result is the same.
When we "google" the error, we can see that it happens regularly since about the version 5.
Did someone has a real clue or a workaround for this ?
note that the code is working. i tested it by downloading it in the flash with the flash programmer. the problem only appears in debug (or run) mode.
"Downloading ELF Process failed"
I sometimes get this error usually when there is a mismatch between the ELF and the firmware I have loaded on the target board. (e.g. the BSP doesn't match the system that the ELF is expecting or the POF/SOF is old or wrong version)
A quick check amost always shows that I have the wrong SOF/POF loaded on the target. Getting close (or exceeding) to memory size can cause problems too.
there is solution for this. Please refer : https://www.altera.com/support/support-resources/knowledge-base/solutions/spr343469.html
regards,
Farabi
Hi
I am facing the same problem. I am trying to download the .elf file but it fails every time. I have searched a lot but still not able to get the solution. I have followed the instruction from this post and attached the screenshot. Can anyone assist me with this problem.
Looks like your NIOS system does not have any memory configured at the addresses starting at 0x1000. You either need to put some memory there in QSYS/SOPC_Builder or use the NIOS linker script to load the data somewhere where you *do* have memory configured.
I'm also facing similar issue while running a simple hello world project through 'Nios II Hardware configuration'. Please see the attachment for details.
Thank you
Babloo
Hello Babloo
several things you need to check for this--
Increase the memory size, check mark the small c library from BSP setting, and also check the interconnections specially between CPU and JTAG in your qsys model.
Rupok
Hi Rupok,
1. As there was a memory issue, self has chosen 'hello_world_small' template instead of 'hello_world' template.
2. And, the small c library is already enabled in BSP settings.
3. Regarding Qsys modelling, I've followed as per the instruction manual for beginners. But at the time of compilation, there is an issue here. Please refer the following thread for more details..
http://www.alteraforum.com/forum/showthread.php?t=51491
Kindly help in proceeding further.
Thank you
