EDS QSPI programming problem
Honored Contributor I
Hi, i’m using my custom Cyclone V SoC(5cseba5u19i7n) board in combination with QSPI flash (Micron 512Mbit).
I want to program the NOR flash via USB blaster with SoC EDS Command Shell version 15.0.
When I start up the “SoC EDS Command Shell version 15.0”and type “quartus_hps.exe –c 1 –o PV ”.
After programming done ,I get the following
"1.send_access_data() error while accessing DP Register. 2.Debug Port Read Buffer reading failure, read_dp_buff() error while accessing AP Register.3.Failed to READ ACCESS to the Physical Reg. 4. Failed to read MPU Module Reset Register."
I was wondering the JTAG was not nomally working.
Thank you.
--- Quote Start ---
Thank you.
--- Quote End ---
I am having the same problem. Have you found a resolution?
Have you found an answer to this? I am also having the same issue (5CSEBA4U)
Except mine says "Failed to release reset register of MPU"
Has anyone resolved this issue?
Kevin.
