we designed a nios2 system in sopc builder and used nios 2 ide for application program. there is no error in the program but .elf file is not generated.
Help us to solve it.Link Copied
Are you sure there is no error in the build log?
Then, you probably have something wrong in the project setting or a corrupted makefile. If you can't find anything relevant, try creating a new application from scratch and add your soruce files.For more complete information about compiler optimizations, see our Optimization Notice.
