:confused:
Hi all, I am getting my quartus code (.sof) flashed correctly using the NIOS II IDE 11.1 - Flash programmer. But the nios code is not getting flashed. i am getting the following warning in problems tab - "WARNING: The expected CPU name does not match the selected target CPU name." and am getting the following messages in processing tab Info: Info: ************************************************** ***************** Info: Info: Running Quartus II 32-bit Convert_programming_file Info: Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=flash/rpctrl_epcs_flash_controller_0.opt G:/rp_ctrl/rpctrl_q101/rpctrl/rpctrl.sof flash/rpctrl_epcs_flash_controller_0.pof Info: Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings Info: Info: Peak virtual memory: 150 megabytes Info: Info: Processing ended: Fri Jan 20 10:53:36 2012 Info: Info: Elapsed time: 00:00:05 Info: Info: Total CPU time (on all processors): 00:00:06 Info: Info: ************************************************** ***************** Info: Info: Running Quartus II 32-bit Convert_programming_file Info: Info: Command: quartus_cpf --no_banner --convert flash/rpctrl_epcs_flash_controller_0.pof flash/rpctrl_epcs_flash_controller_0.rpd Info: Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings Info: Info: Peak virtual memory: 144 megabytes Info: Info: Processing ended: Fri Jan 20 10:53:40 2012 Info: Info: Elapsed time: 00:00:03 Info: Info: Total CPU time (on all processors): 00:00:04 Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Info: Resetting and pausing target processor: OK Info: Reading System ID at address 0x000818E8: verified Info: Info: : Checksumming existing contents Info: Info: 00000000 : Verifying existing contents Info: Info: 00010000 : Verifying existing contents Info: Info: 00020000 : Verifying existing contents Info: Info: 00030000 : Verifying existing contents Info: Info: 00040000 : Verifying existing contents Info: Info: 00050000 : Verifying existing contents Info: Info: 00060000 : Verifying existing contents Info: Info: 00070000 : Verifying existing contents Info: Info: 00080000 : Verifying existing contents Info: Info: 00090000 : Verifying existing contents Info: Info: 000A0000 : Verifying existing contents Info: Info: 000B0000 : Verifying existing contents Info: Info: 00000000 : Reading existing contents Info: Info: 00010000 : Reading existing contents Info: Info: 00020000 : Reading existing contents Info: Info: 00030000 : Reading existing contents Info: Info: 00040000 : Reading existing contents Info: Info: 00050000 : Reading existing contents Info: Info: 00060000 : Reading existing contents Info: Info: 00070000 : Reading existing contents Info: Info: 00080000 : Reading existing contents Info: Info: 00090000 : Reading existing contents Info: Info: 000A0000 : Reading existing contents Info: Info: 000B0000 : Reading existing contents Info: Info: Checksummed/read 44kB in 1.6s Info: Info: 00000000 ( 0%): Erasing Info: Info: 00010000 ( 8%): Erasing Info: Info: 00020000 (16%): Erasing Info: Info: 00030000 (25%): Erasing Info: Info: 00040000 (33%): Erasing Info: Info: 00050000 (41%): Erasing Info: Info: 00060000 (50%): Erasing Info: Info: 00070000 (58%): Erasing Info: Info: 00080000 (66%): Erasing Info: Info: 00090000 (75%): Erasing Info: Info: 000A0000 (83%): Erasing Info: Info: 000B0000 (91%): Erasing Info: Info: Erased 768kB in 7.6s (101.0kB/s) Info: Info: 00000000 ( 0%): Programming Info: Info: 00010000 ( 8%): Programming Info: Info: 00020000 (16%): Programming Info: Info: 00030000 (25%): Programming Info: Info: 00040000 (33%): Programming Info: Info: 00050000 (41%): Programming Info: Info: 00060000 (50%): Programming Info: Info: 00070000 (58%): Programming Info: Info: 00080000 (66%): Programming Info: Info: 00090000 (75%): Programming Info: Info: 000A0000 (83%): Programming Info: Info: 000B0000 (91%): Programming Info: Info: Programmed 725KB +43KB in 18.7s (41.0KB/s) Info: Did not attempt to verify device contents Info: Leaving target processor paused Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Info: Resetting and pausing target processor: OK Info: Reading System ID at address 0x000818E8: verified Info: Info: : Checksumming existing contents Info: Info: 000B0000 : Verifying existing contents Info: Info: 000C0000 : Verifying existing contents Info: Info: 000B0000 : Reading existing contents Info: Info: 000C0000 : Reading existing contents Info: Info: Checksummed/read 58kB in 1.7s Info: Info: 000B0000 ( 0%): Erasing Info: Info: 000C0000 (50%): Erasing Info: Info: Erased 128kB in 1.3s (98.4kB/s) Info: Info: 000B0000 ( 0%): Programming Info: Info: 000C0000 (50%): Programming Info: Info: Programmed 71KB +57KB in 2.1s (60.9KB/s) Info: Did not attempt to verify device contents Info: Leaving target processor paused I am testing with a Char LCD code.. i am not getting the processor to start. I have tested the same code with SRAM and On-Chip memory for the program memory, same result Please help.Link Copied
Hello!
How did you solve this issue? We are fighting the EXACT same thing. Appreciate your help, Thanks!For more complete information about compiler optimizations, see our Optimization Notice.
