12603 Discussions
Eclipse strange behaviour..!!
I don't know whether anyone has experienced this thing or not.
There is a strange thing in Eclipse 11.0.
--> If we add one ".c" file and build project is OK now if we add another c
file by renaming original c file ( any extension except .c i.e .C__) then
also build is ok.
--> Now if we rename new file (.c_) and keep original file by change its
name (".c") then "undefined reference to main".This error pop up."Clean
up" of project doesnot work to eliminate this error
--> Deletion of file (then add again by cleaning project)or copy and paste
content to new files are solutions i found up til now.
This thing are not appeared in Nios II 11 IDE ,seems "Eclipse bug" because after adding new file (changing its name),"Make" file is not able to be updated.
if anyone knows about this,please share over here to avoid future confusions for other people.
Possibly you are confusing things that rely on the timestamps of the files to work out what to build (etc).
