12604 Discussions
Emulating AOCL on Windows: env command issue
First of all, I'm using Windows 64, and everything is okay when I compile and run the hello_example on the SoCKit.
But, to avoid the important time that takes the aocl compilation and synthesis flow, I'm trying to use the emulator option. To do that:
I managed successfully to execute the command "aoc -v -march=emulator device/hello_world.cl --board sockit",
After that, I compiled, without any issue, the hello_world host program.
But, when I try to run the command "env CL_CONTEXT_EMULATOR_DEVICE_ALTERA=sockit hello", I get the following error message:
env: hello: No such file or directory
However, the file hello is there.
Could you help me to find a solution to this problem ?
Thanks and regards.
you run this under admin access right?
