12604 Discussions
Error (10170): Verilog HDL syntax error at nios_system_inst.v
Hello all,
I got the following error while trying the Introduction to the Altera SOPC Builder
Using Verilog Design SOPC Tutorial. I'm using Quartus II 10.0 . I'm lost on figuring it out.
Error (10170): Verilog HDL syntax error at nios_system_inst.v(2) near text "("; expecting ";", or ","
Here is the SOPC auto generated code:
//Example instantiation for system 'nios_system'
nios_system nios_system_inst
.clk_0 (clk_0),
.in_port_to_the_Switches (in_port_to_the_Switches),
.out_port_from_the_LEDs (out_port_from_the_LEDs),
.reset_n (reset_n)
Can anyone assist please, because I am stumped.
Thanks in advance,
I can't see anything wrong with syntax. I am only not sure about where the error is since it says it is located at nios_system_inst.v and this may not mean the code you are showing. I wonder why the file name is same as instant name.
the _inst.v is just an example Verilog instance. you'll need to drop it into a module and port map it
Thank u for replying me..
That was not a code written by me. it was generated by the SOPC.I done it according to the tutorial. But it didnt compile......
I'm getting the same error as mentioned here. Couldn't find any syntactical error in the code. Moreover, it is a Quartus auto-generated code which is not running in Quartus :confused: :rolleyes:. Please help me compile this.
Please do not multipost, it won't get you more answers.
Regarding the error, as already said in the thread an *_inst.v file is just an instantiation example and shouldn't be compiled as is in a project. Remove the file from the project and copy/paste its contents in a top level file if necessary.
