Hi there,
I am building a new component in component editor for SOPC builder. I added 2 package files and a design file for the new component, all in VHDL. When it analyzes the files, it reports an error message like below: Error (10867): Verilog HDL or VHDL XML Interface error at xxxx.vhd(32): port "xxxx" has an unsupported type File:/the path to the design file/ Line: 32. The line in question is a input signal definition in the entity for the new component, it looks like: coe_c0_rx_crc_err_cnt_st : in t_lev2_rx_d_32bit_cnt := (others => (others => '0')); where the t_lev2_rx_d_32bit_cnt is a array type defined in one of the package files, which looks like: type t_lev2_rx_d_32bit_cnt is array(11 downto 0) of std_logic_vector(31 downto 0); I can't find out what the error message is about. Could anyone point out the problem here? Your help will be very much appreciated. HuaLink Copied
BTW, I have compiled these files in QII successfully. It's more like a SOPC SW problem.
Hua- Mark as New
I have the same problem. I need a generic two demision port for address and etc. for my custom component in NIOS system. Did you find any solution?
Topic Options
