12604 Discussions
Error from the tutorial of Generating and Compiling Cyclone V Preloader
SONG
Hi, I have an Error from the tutorial of Generating and Compiling Cyclone V Preloader.
the error message is here
C:\intelFPGA\18.0\embedded\host_tools\mentor\gnu\arm\baremetal\bin\arm-altera-eabi-ld.exe: cannot open map file u-boot-spl.map: Permission denied
Makefile:178: '/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/spl/u-boot-spl' 타겟에 대한 명령이 실패했습니다
make[2]: *** [/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/spl/u-boot-spl] 오류 1
make[2]: 디렉터리 '/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/spl' 나감
Makefile:611: 'spl/u-boot-spl.bin' 타겟에 대한 명령이 실패했습니다
make[1]: *** [spl/u-boot-spl.bin] 오류 2
make[1]: 디렉터리 '/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga' 나감
make: *** [uboot-socfpga/spl/u-boot-spl.bin] Error 2
How can I fix this error?
Abe
Valued Contributor II
The main issue may be due to permissions as the error describes:
" cannot open map file u-boot-spl.map: Permission denied"
Check if your working / code folders have requisite permissions - read/write before executing the make command. Also verify that you are not referencing another user's workspace which might be in read-only mode.
Did you run the command with super-user/root privilages (su make/ sudo make) try running it that way and check.
Fawaz_Al-Jubori
Try to run SoC EDS as Administrator and see if you can overcome this issue.
Fawaz_Al-Jubori
Does the note above helped you Abraham?
ABara8
Hello, I had this problem and cheking prepissions helped me. Files, extracted by untar had only read and exec premissions, so did parent folder
Sperber
I'm facing the same issue.
I tried to change permissions of my code directory to 777
I also tried to change windows permissions for this file.
Can you explain in detail, what worked for you?
Thank you very much.
