Hi, I have an Error from the tutorial of Generating and Compiling Cyclone V Preloader.
the error message is here
C:\intelFPGA\18.0\embedded\host_tools\mentor\gnu\arm\baremetal\bin\arm-altera-eabi-ld.exe: cannot open map file u-boot-spl.map: Permission denied
Makefile:178: '/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/spl/u-boot-spl' 타겟에 대한 명령이 실패했습니다
make[2]: *** [/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/spl/u-boot-spl] 오류 1
make[2]: 디렉터리 '/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/spl' 나감
Makefile:611: 'spl/u-boot-spl.bin' 타겟에 대한 명령이 실패했습니다
make[1]: *** [spl/u-boot-spl.bin] 오류 2
make[1]: 디렉터리 '/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga' 나감
make: *** [uboot-socfpga/spl/u-boot-spl.bin] Error 2
How can I fix this error?
The main issue may be due to permissions as the error describes:
" cannot open map file u-boot-spl.map: Permission denied"
Check if your working / code folders have requisite permissions - read/write before executing the make command. Also verify that you are not referencing another user's workspace which might be in read-only mode.
Did you run the command with super-user/root privilages (su make/ sudo make) try running it that way and check.
Try to run SoC EDS as Administrator and see if you can overcome this issue.
Does the note above helped you Abraham?
Hello, I had this problem and cheking prepissions helped me. Files, extracted by untar had only read and exec premissions, so did parent folder
I'm facing the same issue.
I tried to change permissions of my code directory to 777
I also tried to change windows permissions for this file.
Can you explain in detail, what worked for you?
Thank you very much.
