12604 Discussions
Error from the tutorial of Generating and Compiling Cyclone V Preloader
SONG
I am trying Generating and Compiling Cyclone V Preloader in SoCEDSGettingStarted
The referred SoCEDSGettingStarted's URL is here >>https://fpgawiki.intel.com/wiki/SoCEDSGettingStarted#Starting_the_Embedded_Command_Shell
and I followed the instructions but i have an error at the last step
9. Click Exit in the BSP Editor window box to exit the application.
10. In the Embedded Command Shell, execute the following commands to build the Preloader
cd <SoC EDS installation directory>\examples\hardware\cv_soc_devkit_ghrd\software\spl_bsp
make
11. The Preloader will be compiled ready to be used in the above folder.
I have this error message in EDS command shell
$ make
tar zxf /cygdrive/c/intelFPGA/18.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz
tar: Error opening archive: Failed to open '/cygdrive/c/intelFPGA/18.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz'
make: *** [uboot-socfpga/.untar] Error 1
How can I fix this error plz help me
Fawaz_Al-Jubori
You can fix this issue by following one of the suggestions bellow:
(For each time)
https://forums.intel.com/s/question/0D50P00003yyTozSAE/preloader-make-untar-failing?language=en_US
(one time only)
You can replace the makefile.template available in <your_quartus_installation>/embedded/ip/altera/preloader/src
with the attached one.
Make sure to create new spl_bsp, since the new project will take its makefile from the modified makefile.template
You should see this issue fixed.
Make sure to unzip the attachment first before you copy.
thanks
