12455 Discussions
Error "Pausing target processor: not responding." with VIP
Hi All
I 'm in the last year of my master in microelectronic and I make a project with image processiong.
I try to use this VIP:
Clocked Video Input
Color Plane Sequencer
Frame Buffer
two Clocked Video Outup, one for the 800x600 and the other for the VGA.
I use the tPad Eval Board.
I have also still open the Standalone Programmer for JTAG connection, but I became still this Error Message after compilation in Nios:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and trying again: FAILED
Leaving target processor paused
In Nios I try first the simple hello_world software...
Could anywhere help me please.
Thanks alot
Antonio
Did you upload an FPGA image with a Nios CPU in? Is it an example design or a custom one?
If it's a custom one, check that the clocks are working and that you connected the reset signal properly (the reset_n input of the SOPC component is active low).
This problem normally has something to do with reset problems..
Thanks for the fast answer...
I could fix the bug, I changed the CPU performance on "e", now my custom design works well...
Hi there....
I am facing a quite a similar issue. My post is here (http://www.alteraforum.com/forum/showthread.php?t=33408). Were you able to solve your problem by merely changing to 'e' version of nios??...Could you please elaborate in some detail for the benefit of me as well as the entire nios community?
Thanks in advance :)
