12600 Discussions
Error: s0: Error during execution of "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.b
SThor8
Hi
Windows 10 Pro
Version 2004
OS buid 19041.330
Quartus prime version 20.1 Build 711 standard edition
The platform designer generates the following error.
Error: s0: Error during execution of "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
When the platform designer tries to generate HDL code
I have tried to both switch on and off the  “Windows Subsystem for Linux” according to
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2018/error--s0--error-during-execution-of---c--intelfpga-xx-x-quartus.html
but no luck (seems odd to switch off “Windows Subsystem for Linux” when the bat file Nios II Command Shell.bat is using wsl).
I can from a command prompt execute the bat file (“Windows Subsystem for Linux”  on)
C:\intelFPGA\20.1\nios2eds>
C:\intelFPGA\20.1\nios2eds>"Nios II Command Shell.bat"
Altera Nios2 Command Shell
Version 20.1, Build 711
stefan@DESKTOP-MH7IPN4:/mnt/c/intelFPGA/20.1/nios2eds$ exit
exit
But the platform designer can not execute it, any ideas ?
Info: p0: "ddr3" instantiated altera_mem_if_ddr3_phy_core "p0"
Info: m0: "ddr3" instantiated altera_mem_if_ddr3_afi_mux "m0"
Error: s0: Execution of command "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: s0: /mnt/c/intelfpga/20.1/quartus/bin64/uniphy_mcc.exe -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../system_ddr3_s0_AC_ROM.hex -inst_rom ../system_ddr3_s0_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_USER_ADD_0=0_0000_0000_0000 -DAC_ROM_USER_ADD_1=0_0000_0000_1000 -DAC_ROM_MR0=0001000110001 -DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0001100110000 -DAC_ROM_MR1=0000001000100 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0000000001000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0001001001001 -DAC_ROM_MR0_DLL_RESET_MIRR=0001011001000 -DAC_ROM_MR1_MIRR=0000000100100 -DAC_ROM_MR2_MIRR=0000000010000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=1 -DFULL_RATE=0 -DNON_DES_CAL=0 -DAP_MODE=0 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=0
Error: s0: UniPHY Sequencer Microcode Compiler
Error: s0: Copyright (C) 2020  Intel Corporation. All rights reserved.
Error: s0: Info: Reading sequencer_mc/ac_rom.s ...
Error: s0: Info: Reading sequencer_mc/inst_rom.s ...
Is it possible to get the content from the stderr.txt files ?
IntelSupport
We are in the process of filling a kdb on this.
Description:
Due to a problem in the Intel® Quartus® Prime Standard Edition software version 20.1 and earlier, you may see the error above when you generate the system in the platform designer.
This error happened if you are using updated Windows 10 version and your design consist of DDR4 memory.
workaround:
To workaround the problem, you can follow the steps below:
1) uninstall Ubuntu* 18.04 (if you have one)
2) uninstall wsl
3) re-install wsl
4) download latest Ubuntu 18.04 from Microsoft Shop & install it
5) execute following on Ubuntu shell :
   sudo apt-get update
   sudo apt install wsl
   sudo apt install dos2unix
   sudo apt install make
   sudo apt-get upgrade
Alternatively, you can refer to here for updating the WSL 2 software.
Please take note that Intel does not provide any warranty or guarantee regarding the use of third party software. Hyperlinks to other internet resources are used by you at your own risk.
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Standard edition software.
SThor8
That's was pretty much what I have done, I have even upgraded to wsl --set-default-version 2.
However, I have hijacked the
C:\intelFPGA\20.1\nios2eds\Nios II Command Shell.bat
like this
wsl bash -c '%NIOS2_SHELL_SCRIPT% %*' 2>> c:\temp\test.txt
And the content in the test.txt file result in
/mnt/c/intelfpga/20.1/quartus/../nios2eds/sdk2/bin/nios2-bsp: line 451: nios2-bsp-update-settings: command not found
nios2-bsp: nios2-bsp-update-settings failed
make: *** [setup] Error 1
Line 451 in nios2-bsp look like this
        nios2-bsp-update-settings$windows_exe --settings "$settings_pname" --bsp-dir $bsp_dir --sopc "$sopc_design_file" --script "$default_tcl"  ${default_tcl_options[@]} ${create_update_options[@]} || {
So if I change the line temporarily into
        /mnt/c/intelfpga/20.1/quartus/../nios2eds/sdk2/bin/nios2-bsp-update-settings$windows_exe --settings "$settings_pname" --bsp-dir $bsp_dir --sopc "$sopc_design_file" --script "$default_tcl"  ${default_tcl_options[@]} ${create_update_options[@]} || {
Now the script will "find" nios2-bsp-update-settings and execute it
The problem is that
your are missing paths to your scripts and/or
changing to the installation directory when executing the scripts and/or adding a installation path prefix to your scripts and/or
update the PATH variable so it can find the scripts in /mnt/c/intelfpga/20.1/quartus/../nios2eds/sdk2/bin,
(${_ACDS_ROOT}/nios2eds/sdk2/bin).
The script executing system is currently in directory
/mnt/c/Users/StefanThorlacius/AppData/Local/Temp/alt8456_4792771601944741470.dir/0253_s0_gen/qsys_pre_compile/system_ddr3_s0_software
and can not "find" nios2-bsp-update-settings.exe in /mnt/c/intelfpga/20.1/quartus/../nios2eds/sdk2/bin
Line 451 in nios2-bsp, expanded, look like this
nios2-bsp-update-settings --settings sequencer_bsp/settings.bsp --bsp-dir sequencer_bsp --sopc ../pre_compile.sopcinfo --script /mnt/c/intelfpga/20.1/nios2eds/sdk2/bin/bsp-set-defaults.tcl default_sections_mapping sequencer_mem use_bootloader DONT_CHANGE
it will generate the error message in Generate HDL log window
Error: s0: Cannot find sequencer/sequencer.elf
Error: s0: An error occurred
    while executing
"error "An error occurred""
nios2-bsp-update-settings is a binary file, so I have difficulties to examine this further
SThor8
Hi
Your suggestions is what I did in first place but the error remain
You should change the line 37 in ${_ACDS_ROOT}/nios2eds/sdk2/bin/nios2-bsp from
if [[ $uname =~ "Microsoft" ]]; then
into
if [[ $uname =~ "Microsoft" || $uname =~ "microsoft" ]]; then
On my machine uname will return
uname = '4.19.104-microsoft-standard'
then the nios2-bsp script will be able to execute line 451
($windows_exe will be set correctly)
This get ride of the first execution error and the scripts can move forward.
Now the scripts encounter the following error in the "Generate HDL log"
Which seems to be related to
WARNING: The BSP persisted OS version "9.1" is not available. The default latest BSP version will be used instead.
WARNING: The BSP being loaded used OS version "9.1". The BSP version "20.1" will be used instead.
Makefile:515: Warning: SOPC File C:/Users/StefanThorlacius/AppData/Local/Temp/alt8456_4792771601944741470.dir/0533_s0_gen/qsys_pre_compile/pre_compile.sopcinfo could not be found.
make[2]: nios2-elf-gcc: Command not found
make[2]: *** [obj/HAL/src/alt_dcache_flush_all.o] Error 127
make[1]: *** [../sequencer_bsp-recurs-make-lib] Error 2
make: *** [elf] Error 2
SThor8
If above suggestion to nios2-bsp is correct then line 28 in ………./20.1/nios2eds nios2_command_shell.sh should be changed from
to
as well
SThor8
Additional changes, I guess this come from that I have installed ubuntu as an App under windows.
Quartus have installed the tool chain under
…./intelFPGA/20.1/nios2eds/bin/gnu/H-x86_64-mingw32/bin
and because the latest release of windows, WSL 2 and the ubuntu installation the linux support is no longer identified as "Microsoft" but a true installation.
This will affect how .../intelFPGA/20.1/nios2eds/nios2_command_shell.sh sets up the path.
(around) line 160 in nios2_command_shell.sh it make a test
if grep -q Microsoft /proc/version; then
    if [ -d "${SOPC_KIT_NIOS2}/bin/gnu/H-x86_64-mingw32/bin" ]; then
	    env_var_prepend ${SOPC_KIT_NIOS2}/bin/gnu/H-x86_64-mingw32/bin
    else
    	env_var_prepend ${SOPC_KIT_NIOS2}/bin/gnu/H-i686-mingw32/bin
    fi
else
    if [ -d "${SOPC_KIT_NIOS2}/bin/gnu/H-x86_64-pc-linux-gnu/bin" ]; then
	    env_var_prepend ${SOPC_KIT_NIOS2}/bin/gnu/H-x86_64-pc-linux-gnu/bin
	else
	    env_var_prepend ${SOPC_KIT_NIOS2}/bin/gnu/H-i686-pc-linux-gnu/bin
    fi
fi
But becouse it now is identify the linux as a true distribution the H-x86_64-mingw32/bin directory is no longer identified, the if construction should be changed into
    else
    fi
else
    elif [ -d "${SOPC_KIT_NIOS2}/bin/gnu/H-x86_64-mingw32/bin" ]; then
	else
    fi
fi
The makefile will now find the gcc compiler, nios2-elf-gcc, which is used in the on the fly made Makefile (in my case)
/mnt/c/Users/StefanThorlacius/AppData/Local/Temp/alt8456_4792771601944741470.dir/1625_s0_gen/qsys_pre_compile/system_ddr3_s0_software
SThor8
Sadly I can not continue the investigation, the file /mnt/c/intelfpga/20.1/quartus/../nios2eds/sdk2/bin/nios2-app-generate-makefile.exe
is a binary and it is used in a auto generated makefile.
nios2-app-generate-makefile.exe creates the Makefile
/mnt/c/Users/........…./qsys_pre_compile/system_ddr3_s0_software/sequencer/Makefile
This Makefile is using the tool nios2-elf-gcc, which fails, my guess is that it is using nios2-elf-gcc instead of nios2-elf-gcc.exe.
It also seems it is using the path
C:/Users/............/Temp/alt8456_4792771601944741470.dir/............/qsys_pre_compile/pre_compile.sopcinfo
and not
/mnt/c/User/............/Temp/alt8456_4792771601944741470.dir/............/qsys_pre_compile/pre_compile.sopcinfo
So intel have to take over from here
Conclusion:
1. In file nios2-bsp change the line
into
2. In file nios2_command_shell.sh change the line
into
3. In In file nios2_command_shell.sh change the lines
    else
    fi
else
	else
    fi
fi
into
    else
    fi
else
	else
    fi
fi
4. My guess, fix nios2-app-generate-makefile so it use nios2-elf-gcc.exe if H-x86_64-mingw32/bin installed
5. My guess, fix nios2-app-generate-makefile so it use the correct path to qsys_pre_compile/pre_compile.sopcinfo
Kenny_Tan
I would assume that you have did the steps below:
2) uninstall wsl
3) re-install wsl
   sudo apt-get update
Currently, which version of Ubuntu that you were using?
SThor8
It was in that order I did it,
I also re installed the quartus standard 20.1 from scratch yesterday.
Windows specification
Edition: Windows Pro
Version: 2004
Installed on: 200-07-13
OS build : 19041.330
Expereince: Widnows Feature Experience Pack 120.220230.0
Windows feature "Windows Subsystem for Linux" is checked
(and yes, I have tried to uncheck hithout getting it through the compilation)
I have installed WSL 2 and set the features to 2
Installed Ubuntu LTS 18.04 as an App
$ uname -r
$ uname -s
Linux
$ uname -p
x86_64
$ uname -o
GNU/Linux
$ uname -a
Linux DESKTOP-MH7IPN4 4.19.104-microsoft-standard #1 SMP Wed Feb 19 06:37:35 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
$ dmesg | head -1
[    0.000000] Linux version 4.19.104-microsoft-standard (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Wed Feb 19 06:37:35 UTC 2020
$ cat /proc/version
stefan@DESKTOP-MH7IPN4:~$ cat /etc/issue
Ubuntu 18.04.4 LTS \n \l
$ cat /etc/os-release
NAME="Ubuntu"
VERSION="18.04.4 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04.4 LTS"
VERSION_ID="18.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
The basic problem is that 'uname -r" is returning a string where Microsoft is spelled with a lower case m.
All Quartus script's and Makefile's when building the nios2 assume it is spelled with a uppercase M when taking decisions on the whatever .exe should be added to file endings or not.
This can been seen in for example nios2-bsp
uname=$(uname -r)
Then there is a secondary problem, if I trap and log all output from the compiling stages with hacked files compensating for the little m, this is what happens when trying to compile the alt_dcache_flush_all.c
Info: Building /mnt/c/Users/StefanThorlacius/AppData/Local/Temp/alt8458_2773115126461595135.dir/0729_s0_gen/qsys_pre_compile/system_ddr3_s0_software/sequencer_bsp
make --no-print-directory -C /mnt/c/Users/StefanThorlacius/AppData/Local/Temp/alt8458_2773115126461595135.dir/0729_s0_gen/qsys_pre_compile/system_ddr3_s0_software/sequencer_bsp
Compiling alt_dcache_flush_all.c...
nios2-elf-gcc.exe -xc -MP -MMD -c  -I./HAL/inc -I. -I./drivers/inc -pipe -D__hal__ -DALT_NO_C_PLUS_PLUS -DALT_NO_CLEAN_EXIT -D'exit(a)=_exit(a)' -DALT_NO_EXIT -DALT_USE_DIRECT_DRIVERS -DALT_NO_INSTRUCTION_EMULATION -DALT_USE_SMALL_DRIVERS -DSMALL_C_LIB -DALT_SINGLE_THREADED    -Os -g -Wall  -mno-hw-div -mno-hw-mul -mno-hw-mulx -mgpopt=global   -o obj/HAL/src/alt_dcache_flush_all.o HAL/src/alt_dcache_flush_all.c
nios2-elf-gcc.exe: fatal error: cannot execute 'cc1': CreateProcess: No such file or directory
compilation terminated.
Makefile:543: recipe for target 'obj/HAL/src/alt_dcache_flush_all.o' failed
cc1 is placed in
/mnt/c/intelFPGA/20.1/nios2eds/bin/gnu/H-x86_64-mingw32/libexec/gcc/nios2-elf/9.2.1
It looks like Quartus have installed a Cygwin toolchain
felipegutierrezb
I have encountered the same problem as described above when trying to compile from the Nios II Command Shell.
The simple workaround I have as of now is to compile using eclipse-nios2.exe. In this case it seems like all paths and variables are set correctly.
Dooo
Now Ubuntu 20.04 & version 2 is OK  for  Quartus 20.1.1.
But,  Why must I  uninstall & reinstall  ubuntu ?
I can not understand.
Please Tell me the reason.
Kenny_Tan
SThor8
Kenny_Tan
i had reported this issue to the developer.
Can you do us a favor, install Q19.1 with the patch to see it resolve the issue?
SThor8
Hi
The original project is made in 20.1 and the downgrading did not work well so I could not actually compile it.
However, after applying the 19.1 patch on Quartus 19.1, I could see that the scripts will still fail due to the constructions
uname=$(uname -r)
Kenny_Tan
You may use this design
https://rocketboards.org/foswiki/Documentation/GSRD131CompileHardwareDesign
Check whether emif/hps emif exist there and upgrade the design.
Compile the design in Q20.1 and Q19.1 with patch.
SThor8
Hi
Here is the result, but I guess it does not address the  original problem I have.
Do you want to send my email to the developer so I can test any patches quicker?
Rebgards
Quartus 19.1, no patch, project cv_soc_devkit_ghrd
Platform designer, Generate HDL, Pass
Info: soc_system: Done "soc_system" with 64 modules, 130 files
Info: qsys-generate succeeded.
Info: Finished: Create HDL design files for synthesis
Project, compile: Failed
Error (12006): Node instance "error_adapter_0" instantiates undefined entity "soc_system_mm_interconnect_0_avalon_st_adapter_001_error_adapter_0". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
Info (144001): Generated suppressed messages file C:/Users/StefanThorlacius/Downloads/cv_soc_devkit_ghrd_19_1/output_files/soc_system.map.smsg
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 10 errors, 33 warnings
Error: Peak virtual memory: 5126 megabytes
Error: Processing ended: Fri Jul 17 06:33:04 2020
Error: Elapsed time: 00:03:28
Error: Total CPU time (on all processors): 00:03:36
Quartus 19.1, with patch quartus-19.1std-0.02std-windows, project cv_soc_devkit_ghrd
Error (11802): Can't fit design in device. Modify your design to reduce resources, or choose a larger device. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error: Quartus Prime Fitter was unsuccessful. 1811 errors, 3 warnings
Error: Peak virtual memory: 5181 megabytes
Error: Processing ended: Fri Jul 17 06:42:22 2020
Error: Elapsed time: 00:00:14
Error: Total CPU time (on all processors): 00:00:13
Error (293001): Quartus Prime Full Compilation was unsuccessful. 1813 errors, 120 warnings
Quartus 20.1, no patch, project cv_soc_devkit_ghrd
Warning (15714): Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details
Info (176045): Design uses memory blocks. Violating setup or hold times of memory block address registers for either read or write operations could cause memory contents to be corrupted. Make sure that all memory block address registers meet the setup and hold time requirements.
Critical Warning (169085): No exact pin location assignment(s) for 83 pins of 157 total pins. For the list of pins please refer to the I/O Assignment Warnings table in the fitter report.
Error (174068): Output buffer atom "soc_system:soc_inst|soc_system_hps_0:hps_0|soc_system_hps_0_hps_io:hps_io|soc_system_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|extra_output_pad_gen[0].obuf_1" has port "SERIESTERMINATIONCONTROL[0]" connected, but does not use calibrated on-chip termination
Error: Peak virtual memory: 5182 megabytes
Error: Processing ended: Fri Jul 17 05:24:03 2020
Error: Elapsed time: 00:00:13
Error: Total CPU time (on all processors): 00:00:12
Quartus 20.1, with patch quartus-19.1std-0.02std-windows, project cv_soc_devkit_ghrd
SThor8
Hi
You can see below the result, my guess is that this project do not address the problem I have in our project.
Would it be an idea to pass my email to the developer so we can have fast test and turn around time?
Regards Stefan
Error (12006): Node instance "error_adapter_0" instantiates undefined entity "soc_system_mm_interconnect_0_ava.....................
Error (174068): Output buffer atom ....
Kenny_Tan
I see, can you attached your project to us instead?
might be something missing to fix.
SThor8
Hi
Is there an email address I can send it to, I do not want to post it this thread.
I could not find you on the internal message list.
PS
Note that one of my colleges can compile it, but he is using an older version of Windows 10 and have not WSL 2
DS
Regards Stefan
Kenny_Tan
You may check your email.
Can you compare the windows version? this one happened only on certain windows 10 update.
