Hi All,
I am trying to develop an application for ethernet device. I am using open core device driver which comes with uCLinux. To open an ethernet device i need to get a structure named net_device which is defined into netdevice.h. After including file netdevice.h and compiling application there are following errors displayed. In file included from D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/netdevice.h:28, from test.c:3: D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:136: error: field `ifru_addr' has incomplete type D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:137: error: field `ifru_dstaddr' has incomplete type D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:138: error: field `ifru_broadaddr' has incomplete type D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:139: error: field `ifru_netmask' has incomplete type D:/TOOLS/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/linux/if.h:140: error: field `ifru_hwaddr' has incomplete type test.c:6: warning: return type defaults to `int' test.c: In function `main': test.c:9: error: storage size of `dev' isn't known test.c:14: warning: implicit declaration of function `write' test.c:9: warning: unused variable `dev' test.c:16:2: warning: no newline at end of file make: *** [test.o] Error 1 make: Target `all' not remade because of errors. Here is the part of my application code.. # include<stdio.h># include<fcntl.h># include<linux/netdevice.h> main() { int i,j=0; const char* buf="hello"; struct net_device dev; } Can anybody suggest anything for this? Thanks in advance.Link Copied
