12500 Discussions
Error while compilation process
Hello there,
I am using the 9.0 sp2 version of Quartus II.
When I try to compile my project, the process is stopped due an internal error. I don't know why this is happening. Can anyone help me please?
Here is the error message
Internal Error: Sub-system: AMERGE, File: /quartus/atm/amerge/amerge_kpt_op.cpp, Line: 220
cmp_merge_kpt_db
Stack Trace:
0x3DD57 : amerge_mini_merge + 0x3A977 (atm_amerge)
End-trace
Quartus II Version 9.0 Build 235 06/17/2009 SJ Web Edition
Service Pack Installed: 2
I faced the same issue and managed to resolve it. You can try in the following order and check if it works:
1) Device Pin options - Unconnected pins as input tri-stated
2) Open .qsf file (in notepad) and search for the word HUB. Delete all instances of assignments with word HUB.
3) Delete db and incremental_db from the project file
4) If none of these work...You will need to install another version of Quartus.. Atleast Quartus 9.1 sp2..
Rgds,
BVP
