12603 Discussions
Error while loading rbf file from linux with overlay method
DPaul4
We are trying to load rbf using linux as per the method referenced in this blog
https://forum.rocketboards.org/t/load-fpga-rbf-from-device-tree-overlay-example/999/17
However we are getting the below error.
@socfpga:~# echo load_rbf.dtbo > /config/device-tree/overlays/test/path
[ 6126.498665] OF: overlay: of_build_overlay_info() failed for tree@/
[ 6126.504860] create_overlay: Failed to create overlay (err=-19)
-sh: echo: write error: No such device
The overlay dts file contents are as below
/dts-v1/ /plugin/;
fragment@0 {
target-path = "/soc/base-fpga-region";
#address-cells = <1>;
#size-cells = <1>;
overlay {
firmware-name = "de10_soc.rbf";
#size-cells = <1>;
Fawaz_Al-Jubori
I would like to know if your FPGA was configured before doing the overlay. Furthermore, does the system hangs after doing this overlay? Which Device is this?
DPaul4
Fpga is configured from u-boot. rbf is loaded with load command in u-boot on boot time. problem is when loading from linux. The board used is de10-nano which has altera cyclone V SOC. System doesn't hang after doing the overlay. What is the meaning of the error. Is it like the nodes that we are provide in the overlay file is not present in the base dtb file. It also says no such device. Also do we have to avoid configuring the fpga from u-boot for overlay to work? I tried removing the rbf file which is loaded from u-boot. In this case linux doesn't boot.
Fawaz_Al-Jubori
The Linux will not boot if FPGA is not configured. This is due to the dtb file. It has some drivers that are loaded by kernel. if anything wrong happens to the FPGA, the kernel will break. The recommended flow would be using the generic dtb (which has only the HPS related stuff). Once linux is booting, you can overlay the custom dtb (where it has information about the FPGA image, FPGA IPs, and drivers needed for Linux).
DPaul4
We used the linux image downloaded from the terasic website (Linux Console (kernel 4.5)).
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&No=1046&PartNo=4
When we look into the ./arch/arm/boot/dts/socfpga.dtsi file the node mentioned in overlay is present.
  base_fpga_region: base-fpga-region {
            compatible = "fpga-region";
            fpga-mgr = <&fpgamgr0>;
            #address-cells = <0x1>;
            #size-cells = <0x1>;
any other idea how to debug?
DPaul4
Hi, this issue is resolved by adding following change in
arch/arm/boot/dts/socfpga.dtsi. Now i'm able to load rbf
compatible = “fpga-region”;
fpga-bridges = <&fpga_bridge0>;
I have added this in dtsi file. This seems to be not correct. Could we specify the (fpga-bridges = <&fpga_bridge0>;) modification in overlay? How to do it?
