Hello:
I am currently trying to build Redboot for the Cyclone II 2C35 Development Board. Two errors are being reported during the link phase: 1. undefined reference to perror in altera_avalone_lan91c111.inl. The code is shown below. Does ALTERA_NIOS_DEV_BOARD_CYCLONE_2C35 need to be added to the# if defined list or can I just comment out the reference to perror? /cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/lib/extras.o(.text.altera_avalon_lan91c111_get_esa_wrapper+0x88): In function `altera_avalon_lan91c111_get_esa_wrapper': /cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/include/cyg/sopc/altera_avalon_lan91c111.inl:112: undefined reference to `perror' /cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/lib/extras.o(.text.altera_avalon_lan91c111_get_esa_wrapper+0x94):/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/include/cyg/sopc/altera_avalon_lan91c111.inl:113: undefined reference to `perror' /cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/lib/extras.o(.text.altera_avalon_lan91c111_get_esa_wrapper+0xa0):/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/include/cyg/sopc/altera_avalon_lan91c111.inl:114: undefined reference to `perror' From ../altera_avalon_lan91c111\current\include\altera_avalon_lan91c111.inl: # if defined(ALTERA_NIOS_DEV_BOARD_CYCLONE_1C20) || defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S10) || defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S10_ES) || defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S40) HAL_READ_UINT32 ((void*) (LAST_FLASH_SECTOR), signature); if (signature != 0x00005afe) { diag_printf("This Flash does not contain a valid MAC Address\n"); memcpy(enaddr, static_esa, 6); diag_printf("Using the default of 0x%x:%x:%x:%x:%x:%x\n", enaddr[0], enaddr[1], enaddr[2], enaddr[3], enaddr[4], enaddr[5]); } else { HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 4), enaddr[0]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 5), enaddr[1]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 6), enaddr[2]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 7), enaddr[3]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 8), enaddr[4]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 9), enaddr[5]); }# else diag_printf("This is not an Altera development board\n"); memcpy(enaddr, static_esa, 6); diag_printf("Using the default of 0x%x:%x:%x:%x:%x:%x\n", enaddr[0], enaddr[1], enaddr[2], enaddr[3], enaddr[4], enaddr[5]); perror( "Not an Altera board.\n"); perror( "You need to modify the function altera_avalon_lan91c111_get_esa() \n"); perror( "to set a MAC address for your board");# endif /* (Altera Nios Dev board definition) */ 2. Global Pointer out of range /cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/lib/libtarget.a(redboot_main.o)(.text.do_idle+0x14): In function `valid_address': /cygdrive/c/altera/kits/nios2/components/ecos/ecos-current/packages/redboot/current/src/main.c:756: Unable to reach __RedBoot_IDLE_TAB_END__ (at 0x04000dd0) from the global pointer (at 0x04008e2c) because the offset (-32860) is out of the allowed range, -32678 to 32767. collect2: ld returned 1 exit status make[1]: Leaving directory `/cygdrive/c/Projects/GenOne/Software/eCos/redboot_build/redboot/current' make[1]: *** [/cygdrive/c/Projects/GenOne/Software/eCos/redboot_install/bin/redboot.elf] Error 1 make: Leaving directory `/cygdrive/c/Projects/GenOne/Software/eCos/redboot_build' make: *** [build] Error 2 From ../altera_avalon_lan91c111\current\include\altera_avalon_lan91c111.inl: # if defined(ALTERA_NIOS_DEV_BOARD_CYCLONE_1C20) || defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S10) || defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S10_ES) || defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S40) HAL_READ_UINT32 ((void*) (LAST_FLASH_SECTOR), signature); if (signature != 0x00005afe) { diag_printf("This Flash does not contain a valid MAC Address\n"); memcpy(enaddr, static_esa, 6); diag_printf("Using the default of 0x%x:%x:%x:%x:%x:%x\n", enaddr[0], enaddr[1], enaddr[2], enaddr[3], enaddr[4], enaddr[5]); } else { HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 4), enaddr[0]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 5), enaddr[1]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 6), enaddr[2]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 7), enaddr[3]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 8), enaddr[4]); HAL_READ_UINT8 ((void*) (LAST_FLASH_SECTOR + 9), enaddr[5]); }# else diag_printf("This is not an Altera development board\n"); memcpy(enaddr, static_esa, 6); diag_printf("Using the default of 0x%x:%x:%x:%x:%x:%x\n", enaddr[0], enaddr[1], enaddr[2], enaddr[3], enaddr[4], enaddr[5]); perror( "Not an Altera board.\n"); perror( "You need to modify the function altera_avalon_lan91c111_get_esa() \n"); perror( "to set a MAC address for your board");# endif /* (Altera Nios Dev board definition) */ Any thoughts? TIALink Copied
About first problem,
I have a same problem , It looks likes this eCos configurator supported only few models about below. My case was ALTERA_NIOS_DEV_BOARD_STRATIX_2S60_ES board. so I simply add "defined(ALTERA_NIOS_DEV_BOARD_STRATIX_2S60_ES) || \" #if defined(ALTERA_NIOS_DEV_BOARD_CYCLONE_1C20) || defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S10) || defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S10_ES) || \ #defined(ALTERA_NIOS_DEV_BOARD_STRATIX_2S60_ES) || \ #defined(ALTERA_NIOS_DEV_BOARD_STRATIX_1S40) aqura http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif- Mark as New
aqura:
Thank you for your reply. That is what I thought. However I was reluctant to add the test for the 2C35 board since it was included elsewhere in the code. I will add and rebuild. As for my second error, from this forum (and others) I have added "[]" to the following statements in main.c to modify the addressing from relative to absolute. From: extern struct init_tab_entry __RedBoot_INIT_TAB__[], __RedBoot_INIT_TAB_END__; To: extern struct init_tab_entry __RedBoot_INIT_TAB__[], __RedBoot_INIT_TAB_END__[]; Thanks again........... Graham.....- Mark as New
I am also trying to build RedBoot for a Cyclone-II 2C35.
I have had many of the same problems like yours and I have been using the suggested fixes but I just keep getting to some other error. Did you or anyone else get Redboot to build for the Cyclone-II 2C35? Thanks.- Mark as New
We are in the process of getting the ecos update for Nios II 5.1 ready to go -- this will be addressed in that release.
