I am using the Quartus 4.2 Web Edition + Nios II IDE 1.1 + uclinux 1.3 now. When following the instructions to run "configure kernel", nothing show up. And I cannot build the kernel due to missing the config.h file.
And I cannot grasp the error message when I run the "configure kernel" since the window is closed automaticly. Who can help me out of this problem? This problem really blocks my development work now. Thanks, NeoLink Copied
Did you find the problem? I installed 1.3 and I can't configure the kernel. It worked before with the first version 1.1 I think.
Regards CHristian- Mark as New
There is an entry by Quan that addresses your problem. Give it a try. "newbe to uClinux, having install problem"
Doug
