12435 Discussions
Ethernet and Throughput Efficiency
I have DE3 board with ETHERNET-HSMC CARD and I successes to porting udpofflaod example from alterawiki.
I face problem with throughput efficiency which is unacceptable for me, and I don't know if the problem from netwrok card on PC or on DE3 or there is missing configuration.
The problem is:
The number of packet/second is not change when payload size in ethernet frame change. for example:
if I use maximum payload size 1500 byte, then: 81274.382 packet/second, throughput efficiency 95% (OK)
if I use minimum payload size 46 byte, then: 81274.382 packet/second, throughput efficiency 4% (NOT OK)
packet/second is not change and I see that on Wireshark software.
The problem in throughput efficiency which is less than expected calculation, because the packet rate is the same. expected caluclation:
if I use minimum payload size 46 byte, then: 1488095.238 packet/second, throughput efficiency 20% (OK)
