Hi all,
I am using Quartus II 10.1,Nios IDE 10.1 and a custom board,based heavily on Arria II development board.Currently i am trying to setup a GigE connection.I have a heavy suspicion on PHY working state and/or hardware connection,since i don't see blinking leds of rx/tx and 1000 link.As offered here in the forum on similar occasions,first of all,i should test the connection with simple socket server program.I am using RGMII connection.I have tried both the regular and RGMII versions of simple socket server program.This is the output that i get from the console : Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Can't read the MAC address from your board (this probably means that your flash was erased). We will assign you a MAC address and static network settings Please enter your 9-digit serial number. This is printed on a label under your Nios dev. board. The first 3 digits of the label are ASJ and the serial number follows this. -->Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) 123456789 123456789 Your Ethernet MAC address is 45:fb:5d:ea:65:ea prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x00404000 ERROR : MAC Group[0] - No PHY connected! ERROR : PHY[0.0] - No PHY connected! Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 0.0.0.0 " Any help on resolving/understanding the issue would be welcome . Thank YouLink Copied
First of all make sure all PHY pins are correctly driven; in particular check reset and clock signals.
Then you can probe or Signaltap the mdio interface in order to see if PHY is "alive" and if it answers to hal driver requests. This is a simple two wire serial interface. See page 4-42 of TSE user guide for more info.- Mark as New
4-42?there is no such a page....:rolleyes:
--- Quote Start --- 4-42?there is no such a page....:rolleyes: --- Quote End --- That's what I have. Is a November 2009 version; probably you have a different one. Search the contents for "MDIO" or "PHY Management"
Have you solved this problem? Please help me.
