Hi guys,
i have a stratix II dev board and have to transfer a large amount of data over ethernet. Has somebody tested to tx performance of the SMSC chip? In this forum i found a threat with datarates using the LWip Stack. Are there experiences with other stacks? Thanx a lot regards revoltLink Copied
On the Cyclone (NIOS 1C20 dev kit) board with lwIP stack I have reached speed up to 1.2MByte per second (effective playload) through TCP protocol.
I did not check UDP BW, but i think it can reach 2-2.5MByte per second on the cyclone board.- Mark as New
Hi Major,
thx for your answer. I have to tansmit ~5 MBbyte/s via UDP. I think LWip can't offer the performance. regards revolt
