I modified the example project from CycloneIII starter kit cd. The project runs well except the system timestamp is missing.
Expected system ID: 0x8888 Connected system ID: 0x8888 Expected system timestamp: Not found Connected system ID: 0x8888Link Copied
As You've regenerated the SOPC/QSYS file, You have to regenerate the BSP file also.
Alternatively, you can just ignore the timestamp check in the 'Nios II hardware configuration' window.
Topic Options
