Exponentiation
People,I want to perform an exponentiation in base 10 but the exponent is a variable and this is causing an error in 10,638 at the compilation.I wonder if there is another way to do an exponentiation with the base 10 and exponent is a variable without this error occurs.
what are you refering to? HDL? C?
Please post some code and more details on your problem.
Ok, my code is below.It's a program that converts a number in bcd code to binary code when "c" is 0 and converts from binary to bcd when "c" is 1.The problem is at the exponentiation of the first loop(ebd).
Library ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
Entity conv_bcd_bin_bcd is
Generic(nbitsin:natural:=8;
nbitsout:natural:=12);
Port(X:in unsigned(nbitsin downto 1);
c:in std_logic;
Y:out unsigned(nbitsout downto 1));
end entity conv_bcd_bin_bcd;
Architecture struc of conv_bcd_bin_bcd is
Begin
abc:Process(c,X)
variable aux,cont:integer;
Begin
aux:=0;
cont:=0;
if c='0' then
ebd:for i in 1 to (nbitsin/4) loop
aux:=aux + (to_integer(X(4*i downto 4*i-3))*10**(cont));
if(to_integer(X(4*i downto 4*i-3))<10) then
cont:=cont+1;
else
cont:=cont+2;
end if;
end loop ebd;
Y<=to_unsigned(aux,nbitsout);
else
aux:=to_integer(X);
rdf:for i in 1 to (nbitsout/4) loop
Y(4*i downto 4*i-3)<=to_unsigned((aux mod 10),4);
aux:=aux/10;
end loop rdf;
end if;
end process abc;
end architecture struc;
bcd(8 bits) => binary, needs
multiply MSB digit by 10 and add LSB digit
binary(8 bits) => BCD
divide by 100 then result is MSB digit, divide remainder by 10 the result is middle digit, last remainder is LSB digit
Just off my head, needs verification
Are there another suggestions about it using the same code above?
Well your code sounds like software approach not VHDL.
Your algorithm does not look right especially so the 10**
You must first define a correct algorithm then implement it in HDL
