I am attempting to use sockit as an g_mass_storage device as a quick and dirty USB link.
I get the error "could not insert 'g_mass_storage': no such device" when I run modprobe. I am creating the backing file with the following command: dd if=/dev/null of=./disk-file.img bs=1M seek=1024 count=0 And attempting to load the the driver with the following command: modprobe g-mass-storage file=./disk-file.img I have looked at the device tree and the boot messages, it definitely looks like the Arm is aware of the OTG controller. Thanks in advance, AdamLink Copied
According to this page ...
http://www.linux-usb.org/gadget/file_storage.html You need to partition the backing store before passing it off to the USB gadget driver. Cheers, Dave- Mark as New
Dave,
Thanks so much for your quick response. I had run through the partitioning earlier today with no luck. I did it again and got the same results. The fdisk parameters for the partition creation (n command if fdisk) are sector start/stop instead of cyclinder (which I see in the example). I will continue to cast about for a resolution to this. . . here is my terminal dump with the commands that i ran: root@arrow_sockit:~# dd bs=1M count=64 if=/dev/zero of=./backing_file 64+0 records in 64+0 records out root@arrow_sockit:~# fdisk backing_file Welcome to fdisk (util-linux 2.21.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. Device does not contain a recognized partition table Building a new DOS disklabel with disk identifier 0xe3700929. Command (m for help): x Expert command (m for help): s Number of sectors (1-63, default 63): 8 Expert command (m for help): h Number of heads (1-256, default 255): 16 Expert command (m for help): c Number of cylinders (1-1048576, default 8): 1024 Expert command (m for help): r Command (m for help): m Command action a toggle a bootable flag b edit bsd disklabel c toggle the dos compatibility flag d delete a partition l list known partition types m print this menu n add a new partition o create a new empty DOS partition table p print the partition table q quit without saving changes s create a new empty Sun disklabel t change a partition's system id u change display/entry units v verify the partition table w write table to disk and exit x extra functionality (experts only) Command (m for help): n Partition type: p primary (0 primary, 0 extended, 4 free) e extended Select (default p): p Partition number (1-4, default 1): 1 First sector (2048-131071, default 2048): 1 Value out of range. First sector (2048-131071, default 2048): Using default value 2048 Last sector, +sectors or +size{K,M,G} (2048-131071, default 131071): Using default value 131071 Partition 1 of type Linux and of size 63 MiB is set Command (m for help): t Selected partition 1 Hex code (type L to list codes): b Changed system type of partition 1 to b (W95 FAT32) Command (m for help): p Disk backing_file: 67 MB, 67108864 bytes 16 heads, 8 sectors/track, 1024 cylinders, total 131072 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0xe3700929 Device Boot Start End Blocks Id System backing_file1 2048 131071 64512 b W95 FAT32 Command (m for help): w The partition table has been altered! WARNING: If you have created or modified any DOS 6.x partitions, please see the fdisk manual page for additional information. Syncing disks. root@arrow_sockit:~# modprobe g_mass_storage file=./backing_file ERROR: could not insert 'g_mass_storage': No such device root@arrow_sockit:~#- Mark as New
Thanks for the quick response, Dave.
I had tried the partitioning earlier and had no luck. The parmeters that fdisk asks for are not quite the same as the ones in the example, this bugs me. When I am partitioning it asks me for sector start/stop rather than cylinder. I get the same error with modprobe. Here is the full terminal dump: Sending discover... Sending discover... No lease, failing Starting portmap daemon... Sun Sep 29 01:40:00 UTC 2013 INIT: Entering runlevel: 5 Starting OpenBSD Secure Shell server: sshd NET: Registered protocol family 10 IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready done. Starting syslogd/klogd: done Starting Lighttpd Web Server: lighttpd. Starting blinking LED server Stopping Bootlog daemon: bootlogd. _ ____ ____ _ ___ _ _ _____ _ / \ _ __ _ __ _____ __ / ___| ___ / ___| |/ (_) |_ / |___ / / | / _ \ | '__| '__/ _ \ \ /\ / / \___ \ / _ \| | | ' /| | __| | | |_ \ | | / ___ \| | | | | (_) \ V V / ___) | (_) | |___| . \| | |_ | |___) || | /_/ \_\_| |_| \___/ \_/\_/ |____/ \___/ \____|_|\_\_|\__| |_|____(_)_| arrow_sockit login: root root@arrow_sockit:~# modprobe g_mass_storage ERROR: could not insert 'g_mass_storage': No such device root@arrow_sockit:~# modprobe g_mass_storage file=./backing_fi ERROR: could not insert 'g_mass_storage': No such device root@arrow_sockit:~# ls README disk-file.img readme adam_cool_beans disk_img.img soc_system.rbf altera hello sockit_golden_top.rbf backing_file hps_gpio test.txt bridgeoff.sh led_blink yipee_led bridgeon.sh led_blink_devices.sh clear_leds.sh my_first_hps root@arrow_sockit:~# modprobe g_mass_storage file=./backing_file ERROR: could not insert 'g_mass_storage': No such device root@arrow_sockit:~# modprobe g_mass_storag file=./backing_file FATAL: Module g_mass_storag not found. root@arrow_sockit:~# modprobe g_mass_storage file=./backing_file ERROR: could not insert 'g_mass_storage': No such device root@arrow_sockit:~# dd bs=1M count=64 if=/dev/zero of=./backing_file 64+0 records in 64+0 records out root@arrow_sockit:~# fdisk backing_file Welcome to fdisk (util-linux 2.21.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. Device does not contain a recognized partition table Building a new DOS disklabel with disk identifier 0x5b98fcf9. Command (m for help): x Expert command (m for help): s Number of sectors (1-63, default 63): 8 Expert command (m for help): h Number of heads (1-256, default 255): 16 Expert command (m for help): c Number of cylinders (1-1048576, default 8): 1024 Expert command (m for help): r Command (m for help): n Partition type: p primary (0 primary, 0 extended, 4 free) e extended Select (default p): p Partition number (1-4, default 1): 1 First sector (2048-131071, default 2048): Using default value 2048 Last sector, +sectors or +size{K,M,G} (2048-131071, default 131071): Using default value 131071 Partition 1 of type Linux and of size 63 MiB is set Command (m for help): n Partition type: p primary (1 primary, 0 extended, 3 free) e extended Select (default p): p artition number (1-4, default 2): Using default value 2 No free sectors available Command (m for help): exit e: unknown command Command action a toggle a bootable flag b edit bsd disklabel c toggle the dos compatibility flag d delete a partition l list known partition types m print this menu n add a new partition o create a new empty DOS partition table p print the partition table q quit without saving changes s create a new empty Sun disklabel t change a partition's system id u change display/entry units v verify the partition table w write table to disk and exit x extra functionality (experts only) Command (m for help): q root@arrow_sockit:~# dd bs=1M count=64 if=/dev/zero of=./backing_file 64+0 records in 64+0 records out root@arrow_sockit:~# fdisk backing_file Welcome to fdisk (util-linux 2.21.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. Device does not contain a recognized partition table Building a new DOS disklabel with disk identifier 0xe3700929. Command (m for help): x Expert command (m for help): s Number of sectors (1-63, default 63): 8 Expert command (m for help): h Number of heads (1-256, default 255): 16 Expert command (m for help): c Number of cylinders (1-1048576, default 8): 1024 Expert command (m for help): r Command (m for help): m Command action a toggle a bootable flag b edit bsd disklabel c toggle the dos compatibility flag d delete a partition l list known partition types m print this menu n add a new partition o create a new empty DOS partition table p print the partition table q quit without saving changes s create a new empty Sun disklabel t change a partition's system id u change display/entry units v verify the partition table w write table to disk and exit x extra functionality (experts only) Command (m for help): n Partition type: p primary (0 primary, 0 extended, 4 free) e extended Select (default p): p Partition number (1-4, default 1): 1 First sector (2048-131071, default 2048): 1 Value out of range. First sector (2048-131071, default 2048): Using default value 2048 Last sector, +sectors or +size{K,M,G} (2048-131071, default 131071): Using default value 131071 Partition 1 of type Linux and of size 63 MiB is set Command (m for help): t Selected partition 1 Hex code (type L to list codes): b Changed system type of partition 1 to b (W95 FAT32) Command (m for help): p Disk backing_file: 67 MB, 67108864 bytes 16 heads, 8 sectors/track, 1024 cylinders, total 131072 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0xe3700929 Device Boot Start End Blocks Id System backing_file1 2048 131071 64512 b W95 FAT32 Command (m for help): w The partition table has been altered! WARNING: If you have created or modified any DOS 6.x partitions, please see the fdisk manual page for additional information. Syncing disks. root@arrow_sockit:~# modprobe g_mass_storage file=./backing_file ERROR: could not insert 'g_mass_storage': No such device root@arrow_sockit:~# root@arrow_sockit:~# modprobe g_mass_storage file=./backing_file -sh: root@arrow_sockit:~#: command not found root@arrow_sockit:~# ERROR: could not insert 'g_mass_storage': No such device -sh: ERROR:: command not found root@arrow_sockit:~# root@arrow_sockit:~# -sh: root@arrow_sockit:~#: command not found root@arrow_sockit:~#- Mark as New
Hey Dave,
Thanks for the quick response. I had tried to partition earlier with no luck. I tried again, with no luck. One insoncistency that I saw was that the when I use the "n" option in fdisk that it asks me for start/end sectors instead of cylinders that I see in the example. Thanks, Adam- Mark as New
Here is the terminal dump for the commands that I used:
root@arrow_sockit:~# dd bs=1M count=64 if=/dev/zero of=./backing_file 64+0 records in 64+0 records out root@arrow_sockit:~# fdisk -c=dos Usage: fdisk [options] <disk> change partition table fdisk [options] -l <disk> list partition table(s) fdisk -s <partition> give partition size(s) in blocks Options: -b <size> sector size (512, 1024, 2048 or 4096) -c[=<mode>] compatible mode: 'dos' or 'nondos' (default) -h print this help text -u[=<unit>] display units: 'cylinders' or 'sectors' (default) -v print program version -C <number> specify the number of cylinders -H <number> specify the number of heads -S <number> specify the number of sectors per track root@arrow_sockit:~# fdisk -c='dos' Usage: fdisk [options] <disk> change partition table fdisk [options] -l <disk> list partition table(s) fdisk -s <partition> give partition size(s) in blocks Options: -b <size> sector size (512, 1024, 2048 or 4096) -c[=<mode>] compatible mode: 'dos' or 'nondos' (default) -h print this help text -u[=<unit>] display units: 'cylinders' or 'sectors' (default) -v print program version -C <number> specify the number of cylinders -H <number> specify the number of heads -S <number> specify the number of sectors per track root@arrow_sockit:~# fdisk c=dos Welcome to fdisk (util-linux 2.21.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. fdisk: unable to open c=dos: No such file or directory root@arrow_sockit:~# fdisk -c=dos ./backing_file Welcome to fdisk (util-linux 2.21.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. Device does not contain a recognized partition table Building a new DOS disklabel with disk identifier 0xb4aa408e. WARNING: DOS-compatible mode is deprecated. It's strongly recommended to switch off the mode (with command 'c'). Command (m for help): e e: unknown command Command action a toggle a bootable flag b edit bsd disklabel c toggle the dos compatibility flag d delete a partition l list known partition types m print this menu n add a new partition o create a new empty DOS partition table p print the partition table q quit without saving changes s create a new empty Sun disklabel t change a partition's system id u change display/entry units v verify the partition table w write table to disk and exit x extra functionality (experts only) Command (m for help): x Expert command (m for help): s Number of sectors (1-63, default 63): 8 Warning: setting sector offset for DOS compatiblity Expert command (m for help): h Number of heads (1-256, default 255): 16 Expert command (m for help): c Number of cylinders (1-1048576, default 8): 1024 Expert command (m for help): r Command (m for help): n Partition type: p primary (0 primary, 0 extended, 4 free) e extended Select (default p): p Partition number (1-4, default 1): 1 First sector (8-131071, default 8): Using default value 8 Last sector, +sectors or +size{K,M,G} (8-131071, default 131071): Using default value 131071 Partition 1 of type Linux and of size 64 MiB is set Command (m for help): t Selected partition 1 Hex code (type L to list codes): b Changed system type of partition 1 to b (W95 FAT32) Command (m for help): o Building a new DOS disklabel with disk identifier 0xee0c56f2. WARNING: DOS-compatible mode is deprecated. It's strongly recommended to switch off the mode (with command 'c'). Command (m for help): p Disk ./backing_file: 67 MB, 67108864 bytes 16 heads, 8 sectors/track, 1024 cylinders, total 131072 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0xee0c56f2 Device Boot Start End Blocks Id System Command (m for help): w The partition table has been altered! WARNING: If you have created or modified any DOS 6.x partitions, please see the fdisk manual page for additional information. Syncing disks. root@arrow_sockit:~# modprobe g_mass_storage file=./backing_file- Mark as New
Hi Adam,
--- Quote Start --- I had tried to partition earlier with no luck. I tried again, with no luck. --- Quote End --- Sorry, your response is not clear; you had no luck partitioning the backing store, or you did partition it ok and had no luck with the USB gadget interface using it? I have an SoCKit ordered, but have not received it yet, so cannot try this yet. Cheers, Dave
