Hi, I was looking on the MM Masters Template documentation to understand whether the FIFODEPTH parameter are expressed as bits, bytes or multiples of the DATAWIDTH/ADDRESSWIDTH.
What I read is: parameter: FIFODEPTH range: 4, 8, 16, 32, 64, 128 (default 32) description: FIFO depth of the internal buffer. You should set this to be at least twice the MAXBURSTCOUNT value so that the master operates at peak efficiency.Link Copied
